Highflow Cats what dose mean
c63 , sls , slk55 , e300
im already order headers with xpipe with mid pipe from mbh motorsports
should i order
Removeable Test Pipes*
and
C63 AMG Highflow Cats
should i order
and
'14 C63 507, '11 C300, '96 Cobra, '91 Mr2
Or...you could drive around with the windows up all the time...
Honestly, If you ordered from MBH, they should be answering these types of questions...should be filed under "product support"
Former Vendor of MBWorld
You should get highflow cats if you do not want issues with emissions and your check engine light on. Add the removable test pipes if you plan to track your car or do a lot of spirited driving.
Jacky
Jacky
MBH customer service is very bad im not understand till now what benefit for high cats flow and removable test pipe what he dose with or with out its become check engine on
Cats
Hey I will be taking of cats and installing a pipe with a o2 cat sensor thread so I can hook up o2 but the o2 sensor will just be feeling pressure
Will my light Engine light come on
If you remove your primary cats (the front ones) you will get a CEL even if the rear O2 sensor is installed and working. The rear sensor will sense that the readings are not consistent enough and will set a code.
The above conversation is misleading. If you install headers, you also need a corresponding engine re-tune (a so called header tune). Such a tune normally takes care of the check engine light - independent of whether you use high flow cats or not.
