C63 AMG (W204) 2008 - 2015
Eyebrows, led's, and issues...
Old 10-17-2015, 08:28 PM
johnny--2k's Avatar
2016 ATS-V
So had the aznoptics led's in my eyebrows, and one of the bulbs is bad. Getting it replaced soon, but in the meantime decided to put a regular bulb in there to stop the stupid error message. Well, that was fine for a few days and now neither of the bulbs in that eyebrow work, at all. So I took the lights out of that one and the other one, and just running with no bulbs at all in the eyebrows.
So the next question now is can these be disabled permanently through STAR? I'd rather have nothing then constant issues, plus I'm going to have them wrapped over anyways.
Old 10-17-2015, 08:40 PM
SPONSOR/MBworld Guru
AZN Optics's Avatar
So stock halogen bulb was also throwing codes? Might want to take a look at your wiring as you might have degraded wiring or bad ground wire. No way I believe to disable through STAR, but you can wire in load resistors to run no bulbs with no codes.
Old 10-18-2015, 02:41 PM
johnny--2k's Avatar
2016 ATS-V
Yeah, stock bulbs don't light up at all. Just out of no where both bulbs in the drivers side stopped working.
Old 10-18-2015, 05:26 PM
AZN Optics's Avatar
When you were switching out the bulbs, did you grab and pull by the wire or by the connector? If you pulled by the wire, you might have inadvertently loosened the wire from the socket connector.
Old 10-18-2015, 05:51 PM
johnny--2k's Avatar
2016 ATS-V
nope, grabbed by the socket. I have warranty, so if they are fried, I'll just get the entire thing swapped out for a new unit I suppose.
Quick Reply: Eyebrows, led's, and issues...
