HELP ! Car won't start
2016 c63 AMG S
Went out to start the car and just as the title says, nothing. I had washed the car with the lights on, kids where playing in the car and put the headlights on. So I thought maybe a drained battery ?? So I took the over off and noticed this random connecter.. Any thoughts ?
Yeah looks like a snapped connector on the ground cable.
unbolt one of the bolts slightly and whisk this underneath and then clamp down again.
I agree with HBC350. That wire does not look OEM and was added by someone after delivery. I can't see the other end of the wire so not sure of the reason but for connection of a trickle charger makes sense. I don't see one like it on my 2012. Check it to make sure it is not a hot battery lead or it might short out but a ground lead does make more sense.
You need to charge or replace your battery from the sounds of it.
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
I had to have my battery changed today (1 yr old) after it died the last two days.
Dealership swapped out for a new one no questions asked when they were doing Service A maintenance.
