C63 AMG (W204) 2008 - 2015
Winter tire size help
Old 11-12-2015, 01:39 PM
Cli63's Avatar
2012 c63
I know there are a lot of threads about winter tires, but none of them seem to mention the size they are getting. I have OEM 18" rims and am planning to buy a set of blizzak ws80s. Was planning to just get same size, 235/40 F and 255/35 R, or should i down size to maybe 225 and 245? Also I remember seeing someone running 225 all round, should i go that route? If i should indeed downsize what sidewalls width should i get? Need some advice on this as winter is coming. Thanks. Also to note I live around the Boston area so am expecting a lot of snow.
Old 11-12-2015, 01:53 PM
medamullet's Avatar
2011 C63 AMG
The fronts are 18x8 and the rears are 18x9. The rear will be pretty stretched with a 225. maybe 235/245 all the way around?
Old 11-12-2015, 01:58 PM
medamullet's Avatar
2011 C63 AMG
maybe not that stretched. says 225 will fit on a 7.5-9" rim.
Old 11-13-2015, 06:43 AM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
Depends on where you live and how much snow you get. I have 235 and 255 Blizzak LM32s, but we do not get a lot of snow in the Cincinnati area.
Old 11-13-2015, 07:35 AM
ritalin's Avatar
07 Z06, 2011 c63pp
Im in toronto, got some ws80's in 235/40/18 all around. We usually get a decent amount of snow. I wanted the ability to rotate these over a couple season's.
Old 11-13-2015, 08:44 AM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
I did 245s all around
Old 11-13-2015, 09:01 AM
JeffDL's Avatar
C63
i run 235/40s all around. they look a little stretched on the back but thinner is better for snow.
Old 11-16-2015, 02:20 PM
dreilly36's Avatar
c63 amg
do you think im ok to run 255 40 18 on the rear? i found a set of used blizzaks from a porsche but the rears are different size
Old 11-16-2015, 02:55 PM
Wobble64's Avatar
Yes, that is the size I currently run, since I could not find 255/35/18. A bit larger than stock in diameter but fits without issues. The speedo will be maybe 2 mph off at highway speeds.
Old 11-17-2015, 02:16 PM
Dogtag114's Avatar
2009 c63
If you are in a "regular threat" of snow area and this is your daily, get dedicated rims 4x225 as that is best for snow.
Old 11-17-2015, 03:55 PM
dchl21's Avatar
225 looks like crap on the rears
Old 11-17-2015, 04:29 PM
Dogtag114's Avatar
2009 c63
agreed... just cuts through snow better...
Physics>Aesthetics for winter driving
Old 11-17-2015, 05:46 PM
Wobble64's Avatar
I cringe even thinking about how the 225s will handle when there is no snow...... I am considering to go to 275/35/18 (in Cincinnati). I will still get home from work if it starts snowing and worst case work from home for a day or take the SUV on the couple days with more than an inch of snow on the ground.
But if I lived in Toronto, I would need a different plan.
Old 11-17-2015, 10:40 PM
Cli63's Avatar
2012 c63
I ended up going for 235/40/18 in the front and 245/40/18 in the back. If you are looking for wider tires, I did find 255/35/18s for the ws80s, but they do not have it in the same load rating, so not sure if it is still safe to have them, can always give your dealer a call to see if it is okay. Blizzaks do however offer 255/40/18 for their LM32. Do note, I believe LM32s are more of a well rounded snow tire vs ws80s which are dedicated for snow.
Old 11-18-2015, 11:09 AM
JeffDL's Avatar
C63
i run 235s in the rear for winter. it's not bad need a light foot or you'll burn through them in a week.
Old 11-18-2015, 12:08 PM
Jasonoff's Avatar
Received 1,574 Likes on 927 Posts
2010 C63 AMG
I just leave the nannies on to help prevent that lol.
Old 11-18-2015, 01:09 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
235 blizzacks all around ftw that's what I run does great in the snow.
Quick Reply: Winter tire size help
