C63 AMG (W204) 2008 - 2015
Check Engine Code (Camshafts). Need Help!!!!!
Old 11-16-2015, 05:31 PM
Glbaraban's Avatar
C63 2012
Hey Guys,
I am relatively new to this forum, but was following for a bit of time.
Picked up 2012 C63 with 80k on it. Everything was fine, but after couple weeks and some hard pulls - next day saw an engine malfunction.
Checked with a mechanic: P0736 Continuous camshaft adjustment(left): Incorrect Position of the exhaust camshaft (P0023)
If anyone knows what is it, and how bad is it - please help me.
P.S I dont think that its a sensor, since there is another code for the sensor.
Thanks everybody
Old 11-17-2015, 12:05 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
I'm curious to know more. Sorry about your problem, btw.
Old 11-18-2015, 12:12 PM
Glbaraban's Avatar
C63 2012
Anyone??
Old 11-18-2015, 12:32 PM
deadlyvt's Avatar
2010 C63 AMG
Means you need new aftermarket cams for more powaa! So install and do a write up for us!
In all seriousness sounds like a sensor or something to do with the cam adjusters imo
Old 11-19-2015, 12:48 PM
jclaus98's Avatar
2012 ML63 AMG, 2015 RAM 2500, 1968 Charger
Sounds like either the sensor or the adjuster. If it's just the sensor, I think those run about $100 and they're relatively easy to change. If its the adjuster, which sounds like those are far more prone to failure than the sensor, then those run about $500 and you have to take the valve cover and adjuster cover off and replace the adjuster, then make sure it's timed correctly.
Old 11-20-2015, 07:12 AM
solekeeper's Avatar
A V8
you got ***** buying a 12 with 80k on it lol.
Old 11-20-2015, 09:35 AM
Merc63's Avatar
C63 AMG
Could be the sensor or the cam adjuster has gone bad which is pretty common.
Old 11-20-2015, 10:52 PM
roadtalontsi's Avatar
10 C six trizzle
nothing wrong with 80k and good maintenance records. If anything it's lived an easy life of nothing but highway miles. Which is much better than stop and go city miles. Probably has the original brake pads on it too.
Swap sensors they are all the same, when it comes back on the same one put an adjuster in.
Old 11-22-2015, 10:20 AM
Glbaraban's Avatar
C63 2012
Yeah, I was thinking of the sensor, but the sensor gives another code. Anyways, will try sensor first.
Old 11-22-2015, 10:22 AM
Glbaraban's Avatar
C63 2012
Pads where changed couple months before the car went on sale
Good idea, but price of the sensors is like 20$ each.
Quick Reply: Check Engine Code (Camshafts). Need Help!!!!!
