C63 AMG (W204) 2008 - 2015
I've never seen this kind of dyno before?
Old 11-20-2015, 09:42 PM
solekeeper's Avatar
A V8
woah? someone explain the positives and negatives of this dyno?
Old 11-20-2015, 10:55 PM
INS1GNIA's Avatar
'13 C63 AMG P31
http://www.dynapackusa.com/
Old 11-21-2015, 04:50 AM
Southways's Avatar
C63 Coupe, 2014, 507
One of my favourites...
The good:
  • Very repeatable
  • No variation between cars/days/tyres
  • You don't get dirty strapping it down
  • There is never any damage to the suspension/exhaust etc from chains/straps
  • You get to see what the suspension does under load
  • It is easily portable
  • Can purchase as 2WD & add more pods later
  • Very quiet - no roller whine
  • Very safe to use
The bad:
  • Until you get used to it, attaching to the vehicle can take a little longer. Once you are experienced, there is little difference - it usually takes ~5 minutes total.
  • The software is not as good as Mainline/DynoLog
  • The company is small - based in New Zealand ... but good people. Has had some struggles at times
  • Support is not great
  • Short cars with long doors can be tricky
The DynaPack is great for product & vehicle development. I doubt anything would beat it for consistency of comparative runs.
Old 11-21-2015, 06:45 AM
yellows2k's Avatar
yeah, hub dynos are fairly common in australia, not as common as the roller dynos, but they were around at least 15 years ago, i remember seeing a r34 nur being hooked up to one back in the day
one thing to note, the hub dynos dont play well with the audi r8 s-tronic gearbox. there is a conflict with the software (of the audi) and it wont change up gears to get a run happening
Old 11-21-2015, 06:57 AM
AMG893's Avatar
2010 C63 Estate
Seen these is Aus a fair bit
Old 11-21-2015, 07:21 AM
solekeeper's Avatar
A V8
that is interesting. sounds catastrophic if a tuner didn't know and ended up strapping an r8 up to it..
Old 11-21-2015, 08:15 AM
350Zed's Avatar
'11 C63 P31, '06 Infiniti G35 Sedan (sold), '03 Nissan 350Z (R.I.P.), '15 Toyota Hylander
How is unsprung weight accounted for in the results--e.g., wheel mass?
Old 11-21-2015, 09:29 AM
crazy1eye's Avatar
2016 C63S, 2012 ML350
They also yield much higher numbers, 430-433whp vs 380-382whp on a mustang dyno for my at the time stock '10 P31 C63
Old 11-21-2015, 01:10 PM
solekeeper's Avatar
A V8
so is it more accurate or not? ^
and speaking of accuracy, which dyno is the most accurate?
Old 11-21-2015, 01:35 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
it dynos higher numbers.. and i used it one time and my second gear was messed up right after. never again.
Old 11-22-2015, 07:14 AM
yellows2k's Avatar
no, what happens is the car will keep downshifting back to 2 and wont go higher, so it pulls back the revs. it was a weird sensation, but it wouldnt shift up and stay at that gear. there was no issues with damage
Quick Reply: I've never seen this kind of dyno before?
