C63 AMG (W204) 2008 - 2015
What type of bulb do I need for the side marker lights?
Old 11-21-2015, 08:47 PM
malaka1's Avatar
13' C63 AMG Sedan
I installed clear corners and ordered a set of wedge bulbs which light up just fine but I get an error code in the dash saying left side marker malfunction and right side as well. What wattage do I need, specs/
Old 11-22-2015, 05:18 PM
balthaser's Avatar
2009 C63 AMG
It's about the current they draw. Any 194 incandescent bulbs should be fine. Did you change them to LED bulbs?
Old 11-22-2015, 06:10 PM
SPONSOR/MBworld Guru
AZN Optics's Avatar
194/T10/w5w bulbs are what you need. Same bulb, just has many designations.
If you have LEDs, they have to be canbus type.
Old 11-23-2015, 03:08 PM
malaka1's Avatar
13' C63 AMG Sedan
Amazon.com: TuningPros LEDLP-T10-Y1 License Plate LED Light Bulbs T10 Wedge, 1 LED Yellow 2-pc Set: Automotive Amazon.com: TuningPros LEDLP-T10-Y1 License Plate LED Light Bulbs T10 Wedge, 1 LED Yellow 2-pc Set: Automotive
Tried those got error codes.
Amazon.com: Kolite 2 Pcs 1W LED High Power Wedge T10 With Lens (Spread Type) 100~105 Lumen Cool White 6000K 194 168 501 W5W 12V: Automotive Amazon.com: Kolite 2 Pcs 1W LED High Power Wedge T10 With Lens (Spread Type) 100~105 Lumen Cool White 6000K 194 168 501 W5W 12V: Automotive
Amazon.com: 4 x Yellow LED T10 W5W 194 285 Side Wedge Light Lamp Bulb for Car: Automotive Amazon.com: 4 x Yellow LED T10 W5W 194 285 Side Wedge Light Lamp Bulb for Car: Automotive
Last ones came in today I will try them out.
Old 11-23-2015, 04:18 PM
AZN Optics's Avatar
Might as well not bother taking those out of the package. Hate to tell you, none of those will work. You can't just use any LED bulbs. You'll need LED with specific canbus functionality integrated into the unit or else you'll get error codes and lights will cut off.
Our units will work if interested:
5000K (pure white): http://www.aznoptics.com/index.php?m...products_id=95
8000K (white with a slight bluish hue): http://www.aznoptics.com/index.php?m...&products_id=9
Quick Reply: What type of bulb do I need for the side marker lights?
