check engine after tune
c63 pp 2014
im tune v5 and k&n filter after 3000 kilo check engine light i think engine Brooke
eurocharge tune is safe tune or only for power i don't found any benefit only speedlimt remove and what about k&n alot of ppl he say its better than bmc and no need for clean it till 60000 kilo
im really sad about my engine its new car
From what I've read on these forums, the KN filter oil can gunk up the MAF, which will cause a CEL. Pull the code and see what it says.
c63 pp 2014
Grey/white smoke maybe coolant getting into the engine (head bolts?)
What year of car is it? You say the tune didn't do much, do you have p31, or the 507 package?
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
check if bananas make tailpipe in
'13 C63 AMG P31
I thought the exact same thing. I don't want to say it, but it sounds like operator error...or at least I hope so. Really hope nothing is seriously wrong with the car and it's just something minor.
He probably removed the carbon filter also and has stock air boxes. You will get a code for lean. For the stock stock air boxes and k&n you will get the check engine light and code if you remove the carbons.
The gray is probably at startup. People that are not mechanicly inclined should probably stick with a reputable shop.
