Deck lid rattle disassembly help please
I have a deck rattle comming from the rear tail light deck area behind the back seat on my 2012 C63. I believe I found the problem as 2 of the attachment points are not hooked in. It looks like the deck cover/sub woofer assembly has 3 or so plastic "nubs" that push through a larger hole then slide aft to lock it into place. 2 of those attachment points are not pushed through the metal frame and I'm pretty sure that's why it is vibrating. It looks like it may have not been assembled correctly.
Here is my issue. How do I get that cover off and get to that. It looks like the rest pillar covers need to come off ect but do any of you have experience getting at those parts?
Thanks for any help as I'm sure it will some me some time getting it apart and getting the mounts secured.
Eric.
Eric.
