offset and ADD
offset and ADD
Guys,
I have become cross eyed and filled with saliva looking at all the different wheel setups. I have also become quiet confused as to what is the acceptable/allowable wheel setup. I want to use 19 inch rims with the most aggressive offset with NO! rubbing. I am not lowering the car. The problem is that I am limited by law to adhere to a specific tire size. The front 235/35/19 and rear 255/30/19. Thank you Gurus.
'13 C63 AMG P31
Hi Shamrode,
https://mbworld.org/forums/c63-amg-w...-stickies.html
Most sites will tell you the max offset/size you can use with your vehicle, also writing to the selected wheel vendor helps as well. They will usually be able to recommend the perfect size.
It would be best if we knew where you even wanted to start...
Do you need to keep the same wheel widths?
Any idea on a specific set?
It could be easier for you to post up wheel dimensions when you find something you might want and we'll let you know if it'll work or not.
Not sure how you're limited by law to stick with a certain tire size. I doubt you'd have the metal bracelets thrown on if you ran a 265 in the rear but hey, by the sounds of it you live in a pretty strange place.
But here is a start:
Front: 19x8.5 or 19x9 from +40 to +45
Rear: 19x9.5 or 19x10 from +48 to +55
