C63 AMG (W204) 2008 - 2015
Fixing a tire rub with KW v3 ????
Old 01-23-2016, 01:37 PM
mikegronholz's Avatar
C63 (wife's) E63 (mine) ML63 (gone)
So odd question. I dared Vorsteiner to be wrong, they weren't. You cannot fit a 275 on their V-FF wheel without rubbing. They said 1 customer did, but it took substantial work. So, I tried. I failed (in totally stock form).
With the offset of a V-FF, the outside of the 9.5" wheel is dead on where a 10.5" forgestar is. So, how does everyone fit a 275 on a Forgestar and not rub ?
Can I put a KW v3 on, at factory height in rear, nice and firm and not rub ? Or, fender roll the little bitty lip and just have the paint guy fix the damage when it happens ?
Old 01-23-2016, 04:18 PM
CarHopper's Avatar
E63S | X5
The wider wheel causes the tire to stretch a little bit. That tiny bit of stretch is what helps everyone else clear.
Before I started rolling fenders I'd just downsize to a 265 tire. If you're rubbing now at stock height you'll be rubbing on the v3 as well.
Old 01-23-2016, 04:24 PM
Thanks. I was hoping the v3 maybe would keep the compression at bay at the stiffer settings.
Guess some brand new 275s will be for sale in classifieds ...
Old 01-24-2016, 01:59 PM
CarHopper's Avatar
E63S | X5
I see what you mean, and while there is a small chance that it may work that way, it'll cost you $4k to get the coilovers w/ install at the end of the day. Having v3's without the ability to really adjust them is silly IMO.
Again, this is just what I would do, but downsizing to a 265 will end up costing you only a couple hundred once you offload the 275's and pick up some cash from those.
If money isn't much of a worry you could also try to opt for wider wheels with a more appropriate offset. But now we're starting to talk even more $$ than the v3 route.
Old 01-24-2016, 04:20 PM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
A suspension with a stiffer spring rate will only be an incremental improvement and not a solution. It would just take a slightly harder bump, or a bit more load in the car to still make you rub. You could do that and then drive slow in order to avoid harsh bumps - but then this would be totally counterproductive for enjoying the car.
Slimmer tire or different wheel, or fender modification - those are your choices.
Old 01-24-2016, 05:10 PM
thanks! I'm just going to bite the bullet. I got the 245/275 set for the Renn wheels. So, I'll put them on those wheels and sell them as a set. Ill put Vorsteiner's recommended 235/265 on and survive.
Look for Renn wheels with brand new Conti's at an AMAZING deal !!!
Quick Reply: Fixing a tire rub with KW v3 ????
