Rear Upper Control Arms
Any one heard of these guys?
http://fancyspeedusa.com/
LYKT?
http://www.ebay.com/itm/141791867155?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Anyone know which side is the leveling sensor? Drive or Passenger?
Are the two holes there for the leveling sensor or it still need to be zip tied.
Thanks in Advance!
LYKT?
Thanks in Advance!
They look better than others. I have seen similar products, with both uniball metal joints as well as rubber bushings. The concern with arms like these is usually longevity. While the arm itself is usually aluminum, the adjusting screw and notes are steel and are prone to rust, seize and ultimately break.
Another consideration is that when you adjust camber, toe also changes and needs to be corrected. So you really need to deal with that in addition to camber.
For both of these reasons I recently installed a K-Mac camber bushing set. For details including pictures please see the FAQ section under Suspension. Their quality is outstanding and they handle both camber and toe.
