C63 AMG (W204) 2008 - 2015
Opinions on Weistec Billet Pulley, Oil/Air separator and Uprated Transmission Pan
Old 02-16-2016, 09:36 AM
sirius9's Avatar
W204 C63 saloon
Hi Guys,
Any opinion on these items from Weistec?
Billet Idler Pulley
Oil/Air Separator System
Uprated Transmission pan
Any worth in installing any of these on stock engine with V5 Eurocharged map? Benefits? Cost seems to be the only disadvantage.
Or are these items better installed for those with their supercharger systems?
Thanks in advance.
Old 02-16-2016, 09:57 AM
INS1GNIA's Avatar
'13 C63 AMG P31
Lots have the Oil/Air Separator System, so that one should be easy to find info on. https://mbworld.org/forums/c63-amg-w...r-driving.html. The rest not too sure of.
Old 02-16-2016, 11:16 AM
BLKROKT's Avatar
Received 2,809 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I've got my car in the shop right now getting the Weistec trans pan among other things. My understanding is that it has a number of benefits:
- increased fluid capacity (2.5qt) means that my temps on track will be more stable
- cooling fins on the inside and outside will further reduce temps
- separate fill and drain plugs will allow me to change fluid myself
- extra AN ports will allow me to attach an additional trans cooler if I want
I think if you track your car, it's good insurance at the very least, especially given the cost. Will let you know my findings after I get a few track days on it in March/April.
The oil catch can is a must-do. It's one of the first things you should do to these cars IMO.
Old 02-16-2016, 11:56 AM
CarHopper's Avatar
E63S | X5
As BLKROKT said, the catch can is a great add on.
However, the other things you mentioned, I'd stay away from. They really are meant for a car that will being seeing a ton of track time and just hammered on. If you're DDing yours to work and back everyday then it really is overkill.
Now, if you had a full build going on, or a s/c application, then things like the tranny pan are nice little touches to give you that added peace of mind and performance.
Old 02-17-2016, 01:32 AM
fiat lux's Avatar
2012 C63 AMG
Quick question, for those of you who have the weistec oil/air separator installed, how long did it take to do so? I'm pretty much set on getting it put in, seems like it'll help the life of the engine in the long term.
Old 02-17-2016, 07:57 AM
BLKROKT's Avatar
Should take an hour. It's not hard.
Old 02-17-2016, 12:18 PM
pbaylog's Avatar
2014 C63 Edition 507
Just ordered the Weistec OAS
Will let the group know how the install goes and keep my eye on the catch can...
Old 02-18-2016, 02:22 PM
Alex-r-1's Avatar
C63AMG Coupe 507, GL X166
I use Weistec oil/air separator on my 507. I want to say it really works! (I not drive in winter time)
My post:
https://mbworld.org/forums/c63-amg-w...-question.html
Old 02-18-2016, 09:16 PM
ENVē's Avatar
2001 Porsche 911 Turbo (heavily modified)
I was quoted 2 hours of labor. Wondering if I should try the install myself.
I am pretty mechanically inclined. What would you say the difficulty level is on a 1-10 scale? 1 being totally a joke like windshield wiper blades or 10 being impossible just have someone else do it because not possible.
Old 02-18-2016, 09:31 PM
BLKROKT's Avatar
2.5
Old 02-18-2016, 10:20 PM
roadtalontsi's Avatar
10 C six trizzle
depends do you have -10 an wrenchs, stubby torx and allens? hose cutters? The install is not difficult but considering tool costs and potential to break things it may not be worth your struggle. To me id say 2.5 is a fair assessment but i also rebuild engines, transmissions, perform diagnosis and electrical repairs and have 30k$ in tools.
back on topic, I just installed the weistec transmission pan before my track day a few weeks ago. Great quality piece. I have no hard data or logs to prove anything but I can say fitment and quality are great. I never had any transmission shifting issues or anything. I'll probably change the fluid and see if it's burnt or anything. I will say the power steering system definitely needs a bigger cooler, and i could use some more oil cooling. I was in the beginner group and never got to make an entire lap at full kill but my oil temps creeped up to 270*. They quickly dropped back to 230 when i drove at 60% to keep up with until i got the wave to pass.
The pulleys I wouldn't bother with unless yours are noisy and need replaced. The oil separator will keep your intake manifold alot cleaner and prevent carbon build up and low octane from oil getting in the intake tract with the huge suction our crankcase ventilation systems create.
Old 02-19-2016, 01:21 AM
fiat lux's Avatar
2012 C63 AMG
Awesome, thanks! Both of my indy shops are unwilling to do anything that isn't OEM, so if I can't find anyone to install it, I may have to do it myself.
Old 02-19-2016, 09:24 PM
ENVē's Avatar
I do have stubby torx and allens. I have done a lot of wrenching in the past on cars. Just was wondering if an install guide or video was out there. I am very careful when doing things on cars as I dont ever want to break anything. Hose cutters I do not have and what is a -10 wrench?
Old 02-19-2016, 09:27 PM
BLKROKT's Avatar
Sharp scissors and an adjustable crescent or box wrench works fine
Old 02-21-2016, 07:54 PM
10 C six trizzle
an wrenches.
You dont have to use these, but the an fittings are soft aluminum and scratch/strip easily. These will help with scratching and over torqueing. The size of them is -10.
Quick Reply: Opinions on Weistec Billet Pulley, Oil/Air separator and Uprated Transmission Pan
