Fishcake smoke side marker "silver bulb" question
Based on everyone's recommendation I just purchased the smoke side markers from fishcake on eBay. I plan on installing myself and have seen some good posted about best approach. Although they say 2012-2014 I think the overall agreement was they wil fit my 14...
My question is about the bulb. These come with a silver bulb, wondering if anyone is using the bulbs that fishcake provides or if these are compatible with stock bulbs? I was half way thinking of keeping a yellow bulb to stay somewhat legal. Thanks.
C63 AMG, P30
As long as they're 194 bulbs, you should be perfectly fine.
Don't think anyone is going to pull you over for running a silver coated side marker bulb so you should be good in that regard.
TK32 (02-01-2017)
The silver bulbs do glow orange when illuminated. I like them even though they are a little different color. They look much better in the marker light when not lit. Give them a try at least before you go for the egg yoke look.
TC
i just installed mine yesterday morning... the coated bulb(silver coating) work the same as the original nice amber glow.. though im waiting on some bulbs from azn optics and curious how those would look
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
^ What Mort said. When they're off, you can't even tell there's anything in there. When they do light up, they glow amber - so you are 100% legal.
'13 C63 AMG P31
If you don't want them to glow at all, just install ones similar to these and break the bulb (screwdriver / press hard on each led). The car will read that a bulb is there but there will not be any light emitting.
Oh ok...i emailed him he said the same.. i honestly thought i conveyed what i wanted wrong or ordered the wrong bulb...because when i was trying to get them in it wasnt that easy and didnt want to break them.. i cant wait to see what they look like in the markers...so i put the silver coated bulbs in that were included with the sidmemarkers from fishcake.... the amber glow looks good but i want to see these in....
C63 AMG, P30
yeah i assumed so... i just want to see the glow now and decide which i like more... all white side marker glow with the shine of hid's on the headlights would look pretty uniform which i have no problem with at all....would probably look really good...we will see im gonna take pics of them both and post and make descision... Thanks for reassurance on the fitting of the bulbs
As for the silver bulb, it glows orange and looks good. I def suggest the silver coated bulb.
Best approach? Turn the wheel all the way to one side, pop off the 3 plastic holder pins, pull the plastic back and pull out the bulb (quarter twist and pull). The plastic marker then can be separated and pulled out. Super easy once you see it.
How did you do the install? Through engine compartment or wheel well? Thx!
For the first one I popped my hood and also went through the wheel well so I could get at it from both sides. Once I realized how easy it was I only went through the wheel well for the second one. First side was 10 minutes of dinking around figuring it out and second side was all of 3 minutes.
I purchased the same set (smoked DEPOs from fishcake). I plan to tackle this sometime during the upcoming weekend. I have read that going through the engine bay is the easier method than peeling back the lining of from the wheel area.
OP-
To answer your questions, the silver bulbs light up amber so it is the same when lit up, but make it look much better in the smoke sidemarker than the amber that would stick out like a sore thumb.
I'll post pics here once I am done ...
OP-
OP-
OP-
Two things to keep in mind... first, the OP asked about the legality of the markers. Side markers that glow white - or not at all - are technically illegal. The law states that they have to be amber in colour. Whether your local constabulary enforces it or not is a different question, but unless they glow amber, you *can* get a ticket, which is why using the "mirrored" amber bulbs is the only soution that both looks nice and is 100% legal.
Second, some C63s - about 15-20% of them - have a screw holding the marker in place in addition to the tabs. All side markers housings have the screw hole, but the screw itself was only put in some cars only, without any apparent pattern or logic. If yours happens to be one of those, you have no choice but to take the wheel and fender liner off in order to get to it. Just a word of warning in case you're trying to pop it out the easy way but it won't come out by releasing the tabs alone.
'13 C63 AMG P31
Not everyone likes the corners to shine. Also so the car doesn't give you a bulb out error everytime you start the car lol. I got rid of the demon orange side markers for a reason, don't need them trying to try creep back up to the surface at night lol.
i went thru the wheel well..3 clips to move the cover back, and a clip to get the side marker out.. took me 10 mins tops on each side...you shouldnt have a problem at all
