Need side mirror covers in white or CF!!!
Hey guys, so I have some carbon mirror full replacement covers for my side mirrors and noticed that one side the CF overlay has started to come off/peel away, these side mirror full replacement covers came from RWCarbon, only had them for maybe 6 months. Anyways, Im thinking about just getting some oem white ones, does anyone know where I can get them from? If someone has used mirror covers lying around in a different color or in carbon, I'll buy them too and just have them re-sprayed. Any help would be appreciated, thanks
Hey,
I won't go as far as doing all the updated research, but here's my experience when I wanted OEM CF mirror covers, and did the research ~2 years ago.
First, the CF mirror route:
As mentioned, I bought a set of OEM CF mirror covers about 2 years ago. A member here named Matt, username Olszowa12 had some that were a great price. He prefers email, it's posted all over the forum: olszowa12@wp.pl
If you search for things he's done:
https://mbworld.org/forums/search.php?searchid=17014559
here's his thread specific to the set that I bought from:
https://mbworld.org/forums/c63-amg-w...-c63-w204.html
I will happily state that my transaction with the guy was awesome and easy and they were well packaged and would happily buy from him again.
Second, Buying cheap(er) OEM parts:
Every single time I'm looking to buy parts for the car, I pull up each of these guys below in a new tab, and search for the part number. They all vary their prices every ~3 months and none of them is consistently cheaper than another, so spend 5 minutes searching them all.
I've had good and bad experiences at just about all of them, best recommendation is to just know the part you want and you'll be much better off.
http://mymercedesparts.com/ (EDIT, now looks to be http://www.parts.com)
http://www.oediscountparts.com/
http://mercedespartscenter.com/
http://genuinemercedesparts.com
http://www.mbpartsworld.com
http://www.ecstuning.com
As of 2 minutes ago, I grabbed OEDP and searched for a 2014 C63 and found this:
http://www.oediscountparts.com/parts...agramCallOut=1
Which comes back with prices around $133.50 for the mirror covers, regardless of color.
While searching the same Mars Red (e.g. part 21281008643590) on http://mymercedesparts.com/ (which is now parts.com) is only $102.35
https://www.parts.com/index.cfm?fuse...=Mercedes-Benz
I'll let you search the others if you want.
Anyway
TL;DR
Talk with a forum member called Olszowa12 if you want a CF set, otherwise search around with the above links for a cheap OEM painted set.
Good luck!
Anyway
TL;DR
Good luck!
