need help of intake manifold problems.
I have a 2011 c63 around 48k miles on it, and i am the sencond onwer, the last week I had a rngine light and check from dealer and they said it is the purge valve need to replace. and I did it, after a week engine light pumps on again, and check it, they said it is intake manifold, i have to repalce whole part, but the drive and fule averge not change.
what do you guys think? I am a new, so have no idea. need help, hurry up!!!!
Telling us to hurry up, being so vague, and having this many spelling errors isn't going to get you very far here. Just a heads up.
For starters:
- Where are you located? (Country?)
- Did you pull the CELs?
- Is the car modded?
For starters:
lcx7010 (03-19-2016)
So you did the intake gaskets? The pvc valve on the back can leak, the rubber inside can tear. Some have experienced a crack on the manifold, try locate it and seal it.
