C63 AMG (W204) 2008 - 2015
Knocking noise from steering wheel
Old 03-21-2016, 10:16 AM
elbiba's Avatar
2008 C63
Hi guys,
Last week i had the front stabilizers links replaced at the dealership and since I keep hearing a low knocking sound coming from the steering wheel. It happens when I start turning the steering. I will take it back to the dealership but needed your opinion first in case they try to BS their way out. Any help would be appreciated. I'll post a video when I get the chance.
Old 03-23-2016, 02:20 AM
jay rick's Avatar
C63 2009
Is it a knocking noise when u shake turn the steering?
If so i have the same problem. I believe if could be the steering collum.
I had mine on the c300 as well and i wonder if this is a commom pronlem.
Old 03-24-2016, 09:32 AM
elbiba's Avatar
2008 C63
That's exactly it! I noticed it the moment I got my car back from the stealership
glhansenjr (05-06-2020)
Old 03-24-2016, 01:25 PM
jay rick's Avatar
C63 2009
Interesting, mine didnt develop overnight. It has gradually develop over time and it seems to be be getting worse..
Around 40k miles on the C63 and 55k on C300
My mechanic told told me is the cross knockle inside the steering collum
Old 05-06-2020, 04:51 PM
glhansenjr's Avatar
2009 SL 63 | 2009 C63
I'm going through this right now with the dealership. No knocking, went in for airbag recall, now my steering knocks and the steering is off.
Old 05-06-2020, 08:37 PM
go team's Avatar
2012 C63, GL63, 1989 300CE
2016 revival? It’s probably the securing bolt. This bolt is tapered fit that secures the wheel when you torque down. It’s usually one time use and likely they may have reused it and set it at the proper torque and now the bolt isn’t holding as well as it used to.
glhansenjr (05-08-2020)
Old 05-08-2020, 01:05 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
Just guessing here, but I don't think there would be any need to remove the steering wheel bolt when replacing the airbag. I've not removed the airbag on a C63 but have done so on other cars, and I cannot think of anything they would have done during an airbag replacement that would have caused the steering to feel loose.
Old 05-08-2020, 01:13 PM
glhansenjr's Avatar
Agreed. But to install the knee bolster underneath may have required the wheel to be removed.
Old 05-08-2020, 03:46 PM
go team's Avatar
Yup no need to remove the steering, but then the steering wheel shouldn’t make said noise either if that was the case.
Old 05-08-2020, 03:55 PM
Jasonoff's Avatar
Received 1,574 Likes on 927 Posts
2010 C63 AMG
What knee bolster are you referring to?
Old 05-08-2020, 04:21 PM
glhansenjr's Avatar
The airbag recall was for the front driver & passenger, + knee bolster underneath the driver steering wheel.
In other words, it's just a piece of foam they attach to the steering column area. Very snug fit though, which looks like it would require the removal of the steering wheel.
Attached is the recall PDF for the Takata airbag for 2009 C63.
File Type: pdf
Old 05-08-2020, 06:53 PM
Jasonoff's Avatar
2010 C63 AMG
Thanks, for a min there I thought i had to go digging around for another fkn airbag to yank out.
Old 05-08-2020, 06:56 PM
glhansenjr's Avatar
Hahaha. I'm thinking about taking the foam piece it, it interferes with the automatic steering column, sometimes makes a "crunch" sound and stalls the adjuster.
Quick Reply: Knocking noise from steering wheel
