Valve Gasket DIY - instructions needed
2017 Mini Cooper S Clubman ALL4 - British Racing Green
I let my AllDataDIY subscription lapse.. Does anyone have the instructions (bolt tightening pattern and torque specs, as well as the bolt part numbers)
I have the part numbers for the gaskets themselves.
MB wants 900 to replace the leaking gasket.. screw that.. So I will replace them myself, probably replace the PCV at the same time.
Add this to all my other problems that are all just rolling in at the same time (second idler pulley failed, causing the belt to explode, I had thought it was the Power Steering Pump. The pump is fine, the reservoir is broken)..
When it rains it pours.
Hey how are you? It's been a while.
I found these part #'s for the bolts:
000000002439; 000000001149; 910143006003
GL
GL
