C63 AMG (W204) 2008 - 2015
Door panel removal
Old 04-07-2016, 04:44 PM
dreilly36's Avatar
c63 amg
Door panel removal
Anyone know a video or a link to the front door panel removal? I need to replace a speaker
Old 04-07-2016, 05:05 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
I do not have a video but it is fairly easy.
1- remove the torx bolts in the armrest
2- then use a pry tool to pop out the plastic orange pins. There are many (probably 10). Just be gentle.
3- from that point your panel will only be hung by the top. You'll be able to lift the panel and see the speaker behind. Or just remove the panel by gently push upward. Be careful not pulling too hard because you have your door latch cable as well as your wiring harnesses.
4- Once you disconnect the different cables the panel will be off and you can work on switching your speaker.
GL
Old 04-07-2016, 05:14 PM
chrisridebike8's Avatar
'10 C63
Here's a good thread with pics and stuff
https://mbworld.org/forums/c63-amg-w...ment-long.html
Old 04-07-2016, 05:26 PM
dreilly36's Avatar
c63 amg
Thanks guys. Anybody know how to remove the speaker? I've never seen bolts like this before.
Old 04-07-2016, 05:27 PM
abcut973's Avatar
Not a bolt but a rivet.
Needs to be drilled and replaced.
Old 04-07-2016, 05:29 PM
dreilly36's Avatar
c63 amg
Wow. Any advice?
Old 04-07-2016, 05:31 PM
abcut973's Avatar
Hum ... unless drilling it I don't see how you can remove it.
I never had to replace a speaker so never paid attention to that
Old 04-07-2016, 05:36 PM
abcut973's Avatar
Found a thread on speaker removal but no more pictures.
Basically you need to drill those rivet out and put new ones.
https://mbworld.org/forums/c-class-w...rofit-how.html
edit: as said in page 5 if you are replacing the speakers by OEM then you need the rivets.
Old 04-07-2016, 06:34 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
That's nuts that MB riveted the speakers. In any event, it's pretty simple to drill them out and place new ones in there (of course you will need to have a rivet gun and rivets).
Old 04-08-2016, 03:47 AM
mangosteen's Avatar
w204
That right, You can shot them with .357 rivet gun on them.
Quick Reply: Door panel removal
