C63 AMG (W204) 2008 - 2015
Front & rear brake rotor thickness specs
Old 05-15-2016, 12:11 AM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
A forum search turned up some specs for the PFL front rotors which said:
New 36mm; service limit 34mm; wear limit 33.4mm
Are front thickness specs the same for FL cars?
What are specs for the rear rotors?
Old 05-15-2016, 09:46 AM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
As far as I know the rears are 26 mm. You can also let them wear about 2 mm down to 24 before they need to be replaced.
Old 05-15-2016, 10:16 AM
Rocman8's Avatar
E55
The min spec is stamped on the rotor hub or some AMG model's it's on the outer lip edge of the rotor.
Old 05-15-2016, 07:28 PM
zcct04's Avatar
Thanks Rocman8 - jacking up the car and pulling the wheels should answer my question. I'm just hoping that someone can save me the work. . . .
That's good news. I've worn completely through a set of RB track pads and halfway through of a set of OEM pads. Dealer just did my final service before warranty runs out next week. They measured rotors at 35 front and 25 rear, so I should be in good shape. Thanks!
Old 05-15-2016, 08:41 PM
Rocman8's Avatar
E55
No need to remove the wheels to read the specs. Just need a flashlight.
Old 12-07-2017, 11:08 AM
austintipton's Avatar
C63
Any ideas on how to measure the rear rotor without removing it? The brake shield doesn't have an opening that I can find for my micrometer. I have a flimsy digital caliper, put I don't see space for that and some quarters to get a disc measurement instead of an edge measurement.
Quick Reply: Front & rear brake rotor thickness specs
