C63 BLACK SERIES AXLES
I am toying with the idea of a C63 Black Series conversion, but I am having trouble finding the part numbers for the;
C63 BS (E) axles for the rear
Wheel Carriers
Flanges
Emergency Brake Assembly
I have searched through a few threads and have found that I need these parts but have been unable to locate the necessary part numbers.
Any help is much appreciated!
Wheel Carriers
Flanges
Could anyone confirm that a w212 E63 AMG rear axle would fit a w204 C63 AMG for a Black series conversion? I’d like to widen the rear track without installing spacers.
i was thinking of getting these https://www.ebay.it/itm/114531921547...mis&media=COPY
thanks in advance!
thanks in advance!
I guess I can post as no one has in 5 years haha 😂
axles : 212-350-22-10
rear knuckles :212-350-01-41
I thought I had the other parts but I can't seem to find them it appears like it is all the e63 parts just used on the rear of the bs
it will fit but you need the knuckle,rotor/caliper and some of the parking brake parts I believe. Everything else bolts up if I remember correctly
givigiovi (12-24-2023)
as for the parts, it seems like a more complex process than I anticipated. I pretty much thought the rear axles would have been the only parts I needed to replace. I guess I’d have to track down all the other parts and see if I can get some deals on the web.
thanks again!
Might be easier to buy the e63 rear knuckle assembly and then just bolt it on with rotors and everything all in one piece
I believe the axles are longer on the e than the c as well as beefier.
meery Christmas
meery Christmas
SPONSOR
2007 Mercedes E63 AMG
someone mentioned to me they were not a direct swap. they look mighty close to me.
W212 E63 rear differential top view
W212 E63 rear differential back view
Rear differential Mercedes C-Klasse AMG 6.2 C-63 AMG V8 32V Performance Pack Plus - A1713510108 M156985
MERCEDES W204 C63 REAR DIFFERENTIAL CARRIER RWD OEM
My parts shows
c63 without locking differential :204-350-86-14-80
c63 with locking differenthal :204-350-35-23
e63 without locking differential : 204-350-47-14-80
e63 with locking differential: 204-350-95-14-80
however when I go through the individual parts they are all the same except for the rear cover. So I would take from that they are the same...it also shows the e63 with locking differential as fitting a c63 with performance package/lsd... so not sure why the part numbers would be different if they are the same and fit but who knows sometimes Mercedes does some strange stuff
hachiroku (12-26-2023)
SPONSOR
ya, who mentioned to me said one of the mounts was slightly off. if its the rear cover, easy swap to fix that. differential is the same for all later model AMG's. the downside is the final drive is very tall so this would need to be swapped.
