C63 AMG (W204) 2008 - 2015
Removing Bulb
Old 06-07-2016, 06:34 PM
johnstahhh's Avatar
c63S
Removing Bulb
Hi, I tried searching but nothing came up.
I bought some Xenon bulbs (6000K) to replace the stock 4300K bulbs. I tried getting the bulb out but i do not see any clip to remove it. I did managed to unclip the power source at the bottom.
Does anyone know how to take out the actual bulb itself?? I do have the lighting package, and it is a 12' C63 coupe.
plz halp
Old 06-07-2016, 06:58 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
twist and pull?
johnstahhh's Avatar
c63S
plz halp
Nevermind, I figured it out.
for anyone that needs help on this. Here is the guide.
1. unplug the power clip at the bottom.
2. Rotate the HID bulb itself counterclockwise to loosen.
3. Pull it out slowly and replace with the new bulb.
Also, I purchase from amazon these bulbs. So far so good: Car Rover D1S/D1C High Intensity Discharge (HID) Bulb, (Pack of 2)-6000K)
Amazon.com: Car Rover D1S/D1C High Intensity Discharge (HID) Bulb, (Pack of 2)-6000K: Automotive Amazon.com: Car Rover D1S/D1C High Intensity Discharge (HID) Bulb, (Pack of 2)-6000K: Automotive
Old 06-07-2016, 06:59 PM
johnstahhh's Avatar
c63S
Originally Posted by beejAMG
twist and pull?
yah, it was so easy to do. I feel so dumb now. I spent 30 minutes trying to figure it out. lol. The youtube videos for the w204 are different.
Old 12-14-2017, 01:52 AM
thelinux's Avatar
C63
ok, i took out the bulb by turning it counter clock wise. then tried to put in a new bulb by turning it clock wise. but i now dont remember the correct amount of angle i have to turn. i turned it about 10 degree and it wont go any further. and the bulb is not sitting square to other parts og the headlight and the vertical side of square igniter is not quite at 90 degree from the ground. is this how it is supposed to be? can anyone post a picture showing how the bulb sits in the headlight?
Old 12-14-2017, 02:23 AM
thelinux's Avatar
C63
Originally Posted by thelinux
ok, i took out the bulb by turning it counter clock wise. then tried to put in a new bulb by turning it clock wise. but i now dont remember the correct amount of angle i have to turn. i turned it about 10 degree and it wont go any further. and the bulb is not sitting square to other parts nog the headlight and the vertical side of square igniter is not quite at 90 degree from the ground. is this how it is supposed to be? can anyone post a picture showing how the bulb sits in the headlight?
Never mind. i figured it out. I just had to use more force to turn more. I pushed the wire connector which gave me more leverage.
Old 12-15-2017, 11:58 PM
Alex.currie44's Avatar
2009 SLK55 AMG
(Amazon.com: Car Rover D1S/D1C High Intensity Discharge (HID) Bulb, (Pack of 2)-6000K: Automotive)
You could have also referred to page 117-119 of your manual.
Quick Reply: Removing Bulb
