C63 AMG (W204) 2008 - 2015
C63 shake and vibration
Old 06-08-2016, 08:03 PM
Gurtej Singh's Avatar
2010 C63 AMG
When I start my C63 I feel a bit of a vibration. When I pull out of the driveway and drive around noise goes away. Although there is a shake and a vibration when I stop in gear. Put it in park or neutral it's gone. But if I warm up the car for 10 minutes no noise. What may be the issue? Recently changed PS pump and running k and n filters if that could be a reason. Thanks
Old 06-09-2016, 04:26 PM
Glbaraban's Avatar
C63 2012
Plugs.
Scan the car to be more sure
Old 06-09-2016, 05:05 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Please do a search, this has been covered too much. It could be anything from motor mounts to a dead squirrel. More than likely it is just the V8 you are feeling. It will shake the car a bit. You will also feel it in the brake pedal every so often when stopped. Nothing is wrong with your car, now go wash it and drive around .
Old 06-09-2016, 09:54 PM
Harold1898's Avatar
2015 E400 Coupe
a dead squirrel. love it
Old 06-10-2016, 09:04 AM
ArmoE55's Avatar
2006 E55
Big V8s always have a slight vibration/shaking feeling. Pretty much ever big V8 I've driven has this feeling. Now if it's severe and persistent and impacts normal daily commuting, then it might be something more serious.
Also, assuming you have a 12+ C63, MCT trannys are somewhat finicky... especially from a stop or off the brake. I can't comment on the 08-11 trannys.
Quick Reply: C63 shake and vibration
