Question on where to do res delete in LA area or Anaheim
I figure most indépendant and exhaust shops will do it since its not the 2nd cat you want gone. You can make it easier for them too if you find an x-pipe or straights you want to replace it with. I just got the Mike's power pipe installed and all they had to do was one cut and threw it right in.
No problem with a code for the res delete and tuning is not required as the ECU will adjust if needed. Change in exhaust flow will be minimal but the sound will increase a little and the note will change.
3C Performance can take care of you, also if you're in the LA/OC area you should check out https://www.facebook.com/groups/amg.socal.lounge/ Also no tune needed, and no you will not get a CEL
3C is a great shop. Helped me install 200 cell secondaries and rewelded a cracked MHP X-Pipe after I took delivery of my C63 after shipping from the east coast. In and out in less than an hour, prices were fair and had no problem with me hanging out under the car while they worked. Plus they had a sweet '47 Chevy and Ferrari 456GT to look at while I was there.
Smog Test a few blocks north along La Cienega was also great should you ever decide to go for a more complete exhaust set-up and worry about passing SMOG
