performance Question
i have c63 with mbh headers catless , eurocharge tune , resonator delete . the car after two week the performance become week like the stock any advice from mbworld member
Any CELs?
Flat tire?
Does it have gas?
New chubby girlfriend?
...Nobody is going to be able to answer this with this much info.
Flat tire?
Does it have gas?
Was there any event where the loss in power was immediate?
Or was this a gradual process?
Have you taken it to a mechanic? Seems pretty bizarre that the power has gone down and the tone has changed. Could it be an exhaust leak?
Adding a resonator won't do anything. Lots of people run no resonator without any problems.
do you have a tune
maybe you should tune it
yes maybe exhaust leak what about maf or intake manifold should i clean it ?
tomorrow i will check the exhaust system and return the resonator i hope the performance come like before
after exhuast or before?
did you open the air boxes?? or anything
maybe there no sealed properly
Any dyno pre and post headers & tune?
If so, why not dyno again and see if it still gives roughly the same figures?
Or is it just simply that you got used to the changes?
I certainly do feel like that some days with mine - Headers, sports cats, Eurocharged tune until I give it some hoot and find that I have reached certain speeds in no time...
no dyno post the tune and headers
clean the intake manifold useful or not ? im not clean the manifold ever from 0 mile till now im change the spark already and nothing change
Not sure cleaning the manifold intake will help.
Might be worth removing the Tune/Map and reinstalling it to see if there is any difference.
Failing that, ask Eurocharged for the V5 headers map, which is more specific for those with LTH.
U really need a dyno to see what change and what baseline is the car running, just for future references if issues like this occur again.
COuld you be a bit more specific in the power loss? What actually did you experience? shifting slower? Pulls less strong? cant reach top speed?
Couple people here having similar type issues, frequently having removed airboxes. Forgive me, but I am going to cut n paste my answer from another thread:
Seating and screwing down the airbox properly is vital with this car, and I have had issues with it. You need to screw them down snugly but not too tight, or they will strip. The screws stretch. Yes, stretch. I have even been told by one tech that they were not intended to be reusable. I haven't verified that. But I was plagued by cels when dealing with filters/charcoals etc. Then I bought all new screws. I used thread locker, just a dab. Made sure everything was super well seated. Then I screwed them down. Starting with one. Skipped one screwed down the next one. Around like that, like lug nuts on a wheel. Problems were solved. All good since. If I started getting them again when cleaning the filter, I change the screws. Few bucks. I can usually tell the one that has gone. Try that.
