Noise wavetrac lsd
Noise wavetrac lsd
I have a weird noise coming from my lsd
Was install 2 months ago
Any idea what the problem is with this video
Ive put brand new oil in it and there wasnt any metal piece in the oil
http://http://s560.photobucket.com/u...u1l03.mp4.html
Is that coming from the diff? It doesn't sound like it. Does it speed up the faster you go?
Looks like it makes the tick every one revolution of the driveshaft. Is it hitting anything down stream?
Did you torque the shaft coupling bolts in the proper sequence? They could be flexing as well. I'd try loosening and re-torquing in the proper sequence.
Ididnt install it myself
But 2 weeks ago they also install ltheader xpipe and midsection
Maybe there is something touching the driveshqft
Ill take a closer look at this
I had to edit your link to get it to work for me.
http://s560.photobucket.com/user/gro...u1l03.mp4.html
If exhaust work was done check to make sure the pipes are not hitting the cross brace in front of the resonator. I doesn't really sound like the case but just to be sure. That doesn't sound like the differential to me but rather like the driveshaft is hitting some thing as it turns. GL figuring it out.
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
Could be. I don't know what sounds it's making. Could be the wrong fluid, bad gear mesh spacing, not enough or too many shims. But it should be silent.
I would stop driving it and take it to a good shop ASAP before it becomes a potential driveline disaster.
Ok, just saw the link and clicked it. That sounds very "tinny". Like it's hitting a piece of tin on the revolution. I see some shielding in there, but it doesn't look like it's hitting it from that angle.
