C63 AMG (W204) 2008 - 2015
Oil Temp not displaying CEL
Old 09-14-2016, 03:41 PM
jeffalex1020's Avatar
2010 C63 AMG
The other day my CEL came on while driving to work. The oil temperature was normal but didnt seem to move fast (usually blinks between 2 temps)
Code is p0939- Hydraulic Oil Temperature Sensor Circuit Low. Now it will not display temperature at all. Car runs just fine but I have only driven it once since then. I will be taking it in but I am curious if others have seen this and if its just a new sensor needed.
2010 c63 44xxx miles
Old 09-14-2016, 03:50 PM
Tlnt60's Avatar
2012 C63 AMG Coupe
Might be a silly question, but have you checked your oil level as well?
Old 09-14-2016, 03:58 PM
Mort's Avatar
Sounds like a bad sensor to me. See what the shop says.
Good idea to check your oil level. Probably nothing to do with it but can't hurt.
Old 09-14-2016, 04:03 PM
2010 C63 AMG
You would think I would have check the oil! Will do that today. Getting married this weekend so have to put off taking the car in for about a week
Old 09-14-2016, 04:42 PM
Tlnt60's Avatar
2012 C63 AMG Coupe
Ha! Yea totally get it! Congrats on the wedding! So I think best practice is to get the car up to temp and then let it sit for 10 min then check the oil. But I think given your situation I wouldn't run the motor if you don't have to if it is low oil. If it's so low that it's causing this, then it should register either way I would imagine.
Quick Reply: Oil Temp not displaying CEL
