C63 AMG (W204) 2008 - 2015
Anyone w/ WIS access for PDFs of Removal/Install of: LSD,Idler Pulleys,P31 Brakes?
Old 09-15-2016, 12:09 PM
MBNRG's Avatar
As above; please PM if available.
Much appreciated!
Old 09-15-2016, 12:36 PM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Weistec website has PDF instructions for the pulleys
MBNRG (09-19-2016)
Old 09-15-2016, 12:41 PM
Jasonoff's Avatar
Received 1,576 Likes on 929 Posts
2010 C63 AMG
IIRC there's nothing in the WIS for diff internals. Just a backlash spec. I am going off rusty memory from 5yrs back though.
MBNRG (09-19-2016)
Old 09-19-2016, 05:53 PM
MBNRG's Avatar
Thanks, guys.
Jason you are correct, there does not seem to be much if any parts diagram or servicing advice for diffs for our C63, but appears the same LSD, carrier, bearings, shims, etc are available on other models, in particular E55/W211 platform. May have to look there.
Can anyone who has measured their bearing Preload and Backlash settings on their Stock LSD before switching to Wavetrack/Quaife share what they found?
What are the correct torque specs for the bolts of the diff's Ring Gear, etc?
Old 09-20-2016, 07:06 AM
Jasonoff's Avatar
2010 C63 AMG
WaveTrac told this guy 75ft-lbs, but I think I did my to 80ft-lbs --> https://mbworld.org/forums/c63-amg-w...ml#post6808667
I didn't write down my backlash and it was too long ago to remember the exact values. I remember it was on the low side of the OEM spec and slightly higher after the WaveTrac still within spec.
MBNRG (09-21-2016)
Quick Reply: Anyone w/ WIS access for PDFs of Removal/Install of: LSD,Idler Pulleys,P31 Brakes?
