750rwhp plus fuel set up - what did you do?
Just throwing this out there to see if any one is kind enough to share info on what they have done to improve fuel supply above 700rwhp. Stock fuel system caps about 700 and I'm about to hit that real soon. I have an idea, looking at using the standard pump as a lift pump to a surge tank, then using 2 for example bosche 044 pumps, from the surge tank to the engine. Obviously it will be limited by how quick the pumps will finish the surge as it that will exceed the amount the stock pump can push into the surge. I can also look at a custom Intank set up but I haven't looked at the stock pump yet. I'm just chasing ideas for my build.
H
H
there is a solution but i charge 5 bux for it lol
ill send it over to both of you
