Oil Pan Bolt Torque Specs?
I have a little seep around one of the corners of the oil pan. Planning on dropping it and resealing it. Anybody know the torque specs for the oil pan bolts? I believe the bolts is a 6x20.
This looks like a 8 -9 hour job on Alldatadiy.
Torque specs for pan to block and lower pan to upper pan is 8.4 Nm and the bolts are M6.
There are also notes on the application of sealant.
Alldatadiy gives the estimated times to change the Oil Pan Gaskets as - Upper Gasket 6.8hrs and Lower Gasket 1.9 hrs.
The main reason for the time is that you have to raise the engine.
