Comfort/sport mode button stuck?
C63 AMG
Good morning everyone..wanted to know if anyone knew how to remove the button that I'm pointing at in the picture..? Something mightve spilled without me even noticing I guess...anyone know how I can remove that button so I can clean it with some electronic cleaner spray? Thanks in advance..!
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Stick your hand inside the leather part of the shift knob cover, and pull up on the edges. Once you pull that up and out you might have access to whatever else is down there.
That's my best guess, someone else might know better.
This DIY for the centre console should help. See post 1 step 3 to 5.
https://mbworld.org/forums/c-class-w...e-removal.html
GL
GL
Up until recently I was in an 09, which will stay in a mode even after you turn it off. I had mine in S for so long that I forgot that was even a button. When I first saw this post I chuckled to myself thinking "this guy thinks that light is actually how you change modes".
Spill coffee down there? my CLR and Back buttons get stuck from that... best to get a hot rag and lay it over top, then use a "calling card" or coupon card (like Kohls or GNC) to get in the crack...
