C63 AMG (W204) 2008 - 2015
Car Jerking, Hesitation, and rough idle
Old 12-24-2016, 07:43 PM
Drokas's Avatar
Mercedes benz Ml63 AMG
Gents,
i Have another issue with my car now,
a week ago the engine light came on after the dealership changed my intake manifold,i took the car to a mechanic shop to get the codes as mercedes was closed,i cleared the codes and called mercedes and explained the situation when they opened, the service advisor told me its probably because we changed the intake manifold gasket so car is re-adjusting, so once cleared the car ran fine with a few light hesitations here and there but nothing major,
yesterday the engine light came on again, took it to a friends mechanic shop to pull the codes and now its reading, P0101, P010b, P0133, P0153,
Doesn't run too bad on idle but once i accelerate car seems to choke, bog down,and jerky at steady acceleration, backfire etc(basically can't drive it now)
WTF Is going on with my car!!
P0101(The measured right air mass is implausible compared to the position of the throttle valves)
P010b(The measured Left air mass is implausible compared to the position of the throttle valves)
P0133 (G3/4 Right o2 sensor before TWC[KAT]:aging signal Impolse/Short circuit to ground)
P0153 (G3/3 Left o2 sensor before TWC[KAT]:aging signal Impolse/Short circuit to ground)
Please Help
Old 12-24-2016, 08:23 PM
faz492's Avatar
e63 amg w212 6.3
Welcome to the club!!
My car is going through the similar as well as Jacked's.
The following 2 users liked this post by faz492:
Drokas (12-28-2016), Jacked a c63 (12-27-2016)
Old 12-24-2016, 08:36 PM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Use some periods next time that was painful reading
Do a search these are common codes and symptoms that have been discussed many times. Good luck.
Old 12-26-2016, 10:02 AM
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
Since you have just changed the intake manifold, I would guess there is a leak somewhere.
Old 12-26-2016, 07:41 PM
faz492's Avatar
e63 amg w212 6.3
02 sensors, sparkplugs etc etc etc etc etc $$$$ later ur car is still messed up xD?
Old 12-27-2016, 05:16 AM
Jacked a c63's Avatar
2009 C63 AMG, 2013 CLS63 SAMG, FORD F350, BMW 750LI
This is great! What a way to end 2016. We all have broken cars going into the 2017. Wouldn't be surprised if my CLS63S breaks down in the next few days!
Old 12-28-2016, 08:46 PM
Drokas's Avatar
I just got my car back from Mercedes Benz and apparently one of the sensor plugs had a loose connection, its all good now and running great!!
Jacked a c63 (12-31-2016)
Old 12-28-2016, 09:55 PM
faz492's Avatar
e63 amg w212 6.3
Can u tell me which sensor plug?
Old 12-28-2016, 10:28 PM
AMG6.3's Avatar
C63
U have a leak probably a vacuum leak. Take it back to dealership they should fix it for free if you had new intake.
Old 12-28-2016, 11:41 PM
CarHopper's Avatar
E63S | X5
Bet money that it was an o2 connector?
Old 12-28-2016, 11:55 PM
faz492's Avatar
e63 amg w212 6.3
If only it was that simple ill have my changed next week.
Quick Reply: Car Jerking, Hesitation, and rough idle
