Sign in using an external account
| CL-Class (W215) 2000-2006: CL 500, CL 600 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2003 V12 CL600, a Supercharged 2002 Z06, an 89 Corvette and an 07 Jeep Wrangler
Where is the drain plug on my CL600?
#2 |
Drives: '02 CL500, '91 Mark VII, '76 Vette
You have to drop the plastic pans that are located under the car. The ones under the engine to be specific. You should then see the oil pan and its drain plug.
__________________
2002 CL500 1991 Lincoln Mark VII 1976 Corvette |
#3 | |
Quote:
I figured it out last night once the plastic pan was removed. It was on the side of the oil pan.Thanks again and I hope you had a nice Thanksgiving! Andrew |
#4 |
You're welcome. I just went thru it today as I changed the oil and filter in my CL500. In defense of those who did not answer your question, this forum I find not to be highly technically oriented. They probably just didn't know.
__________________
2002 CL500 1991 Lincoln Mark VII 1976 Corvette Last edited by Jud Chapin; 11-29-2009 at 04:58 PM. |
#5 |
#6 |
Drives: 98 GS400, 86 MR2, and more
how many Litres you've used in your 600? and what weight? Thinking of changing my parent's oil also when I'm back visiting them...
#7 |
Drives: CL500
#8 | |
Quote:
__________________
| Tags |
| 02, 2006, 500, 600, benz, change, changing, cl, cl600, drain, forum, mercedes, oil, plug, weight |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
