CL-Class (W215) 2000-2006: CL 500, CL 600
ABC problem on 02 cl500 pllllllllzzzzzz help :)
Old 09-27-2012, 01:41 PM
Super Moderator
awiner's Avatar
2003 CL55 AMG
Pulling the codes via DAS/SDS will tell you what to start looking at.
Old 05-16-2013, 07:20 PM
midwestdiva69's Avatar
02 cl500
Originally Posted by mikecl600
hello everyone im new here i been a mercedes tech for years and now have my own shop i have a cl500 and i have done more ABC work then i can count if any one needs help with any abc problem let me know i olso have 2 abc pumps and 2 valve blocks for sale real cheap...
..........where are u located I have a issue with my first passenger strut on my 02 cl500
Old 05-16-2013, 07:25 PM
02 cl500
My airmatic visit workshoplight is on and I took it and got a rodeo done car lift normal when turn on and lowers properly when turned off but I got the airmatic system code check and it says front right strut moves eventhough locking valve is closed can that be fixed without replacing strut? I think it was a default. code..1531. You can reply back to me at..midwestdiva69@hotmail.com
Old 05-16-2013, 10:32 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
You don't have an airmatic system on your car. Your car has the ABC system that uses hydraulic fluid.
R.K.
Old 05-16-2013, 10:36 PM
02 cl500
Well can u tell me why I have a airmatoc visit workshop light on then?
Old 05-16-2013, 10:38 PM
02 cl500
So the ABC system makes my car raise and lowers? I'm a female so I'm slowly learning about mechanical stuff.
Old 05-17-2013, 09:56 AM
  #32
radride's Avatar
Do you have a CL500 or CLS500?
R.K.
Old 05-17-2013, 10:16 AM
  #33
02 cl500
Cl500
Old 05-18-2013, 09:53 PM
  #34
mf219's Avatar
2004 CL500
I've never heard of a CL with airmatic
Old 05-18-2013, 10:59 PM
  #35
Super Moderator
awiner's Avatar
2003 CL55 AMG
Because they don't exist
Old 06-15-2013, 06:04 PM
  #36
atccompany1's Avatar
2001 cl 600
I have A 2001 cl 600, GREAT CAR but when the ABC goes it really goes. It has been in the shop at least 6 months out of the last two years figuring out the ABC issues. Pump was replaced, lines replaced and shock replaced. It still slowly goes down on the right rear after a couple of days but will come back up when started. I guess the valve block is the only thing I didn't have replaced. Doe's that sound about right?
rwolak (10-03-2021)
Old 06-15-2013, 08:42 PM
  #37
Super Moderator
awiner's Avatar
2003 CL55 AMG
Yes, if the shock was replaced on right rear it is the valve block.
Old 10-12-2015, 11:48 AM
  #38
I am benz's Avatar
Cl500, 450SL
Hi mikecl600, do you still have the valve blocks? front?
Old 05-02-2016, 03:45 PM
  #39
kaiserkia1234's Avatar
2004 cl500 coupe
cl 500 sagging
hi this is the first on the site replaced nsr strut with a good second hand one my pump is noisy but the old strut which did have a leak did come up level even tho it was faulty since the replaced second hand unit it is lower by about 1 inch can you help and can you supply me with one of your pumps i live in northern ireland uk thanks Barry
Old 05-02-2016, 04:11 PM
  #40
tusabes's Avatar
Mercedes
This is an old thread he might not have the pump
The cheapest pumps in the USA are at rockauto.com about $250. see if they wil ship to you or find a buddy in the USA to get the package and mail it to you if they won't ship internationally
Old 05-03-2016, 11:50 AM
  #41
Jack_88's Avatar
2018 C300
I would suggest not getting the cheapest part you can find. I would recommend trying to get the OEM replacement. Since the car was manufactured, the replacement parts are more robust. Is the Rockauto part an OEM piece or China/Reman unit?
Old 05-03-2016, 10:16 PM
  #42
calgary's Avatar
2001 Mercedes CL500 2006 E350 4-matic
I believe the pump shown by rockauto is a power steering pump for about $250.00, not a tandem pump. I cannot find an ABC pump listed by them.
Old 05-03-2016, 11:51 PM
  #43
tusabes's Avatar
Mercedes
The power steering pump is the tandem pump
Old 05-04-2016, 02:30 PM
  #44
Super Moderator
awiner's Avatar
2003 CL55 AMG
Be careful, there is a power steering pump only option.
The pumps in the $200+ range on RockAuto are the tandem pumps. The pumps in the $100 range are non tandem power steering only.
Old 05-04-2016, 09:05 PM
  #45
calgary's Avatar
I have never seen a tandem ABC pump for the W215 in the $200+ range..
not even used ones ...
Old 05-04-2016, 09:21 PM
  #46
Super Moderator
awiner's Avatar
2003 CL55 AMG
You have now :-) Rock Auto has had re-manufactured tandem pumps for a while at $225-$275....
  #47
ItalianJoe1's Avatar
2003 CL 600
http://www.rockauto.com/en/catalog/m...ring+pump,7380
Old 05-05-2016, 04:31 AM
  #48
tusabes's Avatar
Mercedes
They didn't exist till recently. They Used to be very expensive
Very cheap now . Napa auto parts also sells them at a higher price
Old 06-17-2016, 07:42 AM
  #49
frank123's Avatar
cl500
Too early to throw money at it, drive on a bumpy road, raise and lower the car a lot of times, get it working, load it up with something heavy and do it again and again, Then check for leaks on the ground.
Check youtube for the abuse these can take, don't *****foot - if it's a blockage or a dud 3 micron filter in the abc oil tank who knows ?. Go max height and park over night all this helps. Frank.
Old 06-17-2016, 08:00 AM
  #50
frank123's Avatar
cl500
NB, my last post used the words cat foot (-----) around which is ok here in the uk
but not here - so point noted.
Frank.
Quick Reply: ABC problem on 02 cl500 pllllllllzzzzzz help :)
