CL-Class (W215) 2000-2006: CL 500, CL 600
abc pump install
Old 10-12-2015, 01:15 AM
  #51
clrockford's Avatar
04 sl 600
abc pump
Originally Posted by tusabes
So your abc raise /Lower button does work to raise and lower the car ?
Yes I hand spun pump before Starr after start button took a few presses to work then did also after start return line was pumping fluild right away so I'm assuming pump is properly lubricated cycled up n down 40 times I have to.lights on dash didn't even get one but I do notice that if I open door and put in drive that I don't get the red warning like I used to same with parking brake very lost
Old 10-12-2015, 06:35 AM
  #52
tusabes's Avatar
Mercedes
A working abc system
But bouncy ride is usually bad accumulators . Again you'll need a Mercedes dealer or independent Mercedes shop with the computer to run tests
Old 10-12-2015, 05:19 PM
  #53
clrockford's Avatar
04 sl 600
abc pump
After hoses repair it became bouncy before was great but leaked 3 of those are new
Old 10-13-2015, 10:34 PM
  #54
clrockford's Avatar
04 sl 600
Buying star c4 kit will be renting it out for 25$ for 2 weeks requiring a deposit refunded upon return of star das
Old 10-14-2015, 09:50 AM
  #55
biker349's Avatar
cl600
could possibly be air in the lines. i believe if it is it will correct itself and bleed the air over time, or do a rodeo. make sure you keep checking your abc fluid in case air is escaping.
Old 10-14-2015, 10:33 AM
  #56
clrockford's Avatar
04 sl 600
ABC b ose replacment
Well I'm sure the pump was primed only thing I'm unsure if I did right was before start up I lifted all 4 wheels to where they would sit when driving then started the car maybe I should of started it on the ground let it raise itself up
Quick Reply: abc pump install
