CL-Class (W215) 2000-2006: CL 500, CL 600
Door handle button is missing
Old 05-12-2011, 07:03 PM
StUnT66's Avatar
2004 CL500
My door handle lock/unlock button must have popped off somewhere.
Does anyone know where to get a replacement button and how I would even attempt to properly install it?
It's a 2004 CL500 and its on the passenger side.
Thanks so much,
Chris
Old 05-13-2011, 08:30 AM
saintz's Avatar
GL450
I am curious, too. My passenger button is broken, and I couldn't find the replacement in the parts catalog.
Old 05-14-2011, 11:17 AM
StUnT66's Avatar
2004 CL500
Wow it doesn't look like we are getting our door handles fixed.
I'm really not sure what do at this point. Is it even safe to drive in the rain? Will it short?
Old 05-14-2011, 01:08 PM
mf219's Avatar
2004 CL500
I'm not really sure what you mean by a "door handle button" ? I too have a 2004 CL500, and it doesn't have any buttons on the door handle. Maybe you can better explain what it is you're talking about.
Old 05-14-2011, 01:10 PM
Richie999's Avatar
2011_C350
post a pic, we can help you find a part number.
Old 05-14-2011, 02:29 PM
StUnT66's Avatar
2004 CL500
With and without
Old 05-14-2011, 02:32 PM
StUnT66's Avatar
2004 CL500
can you guys see those links?
Old 05-14-2011, 04:07 PM
Richie999's Avatar
2011_C350
That's a missing door handle button!
Try this.....
http://www.mercedespartscenter.com/p...layCatalogid=0
Old 05-14-2011, 11:18 PM
saintz's Avatar
GL450
It's the keyless go lock button on the door handle. Not sure if that part is right.
Old 05-15-2011, 11:59 AM
mf219's Avatar
2004 CL500
OK, I understand now that I see yur pics & saintz's comments. My car doesn't have keyless-go so no buttons on my door handles. Sorry I couldn't help. Hope someone here can.
Old 05-15-2011, 12:34 PM
StUnT66's Avatar
2004 CL500
Thanks, I might be screwed on this one.
Old 05-15-2011, 06:05 PM
chuckace's Avatar
2005 CL 500
I hate to be the bearer of bad news but I just fixed my handle about 2 weeks ago and can tell you it's pricey. The entire handle has to be replaced. Part number is 21576005709999-$234 plus shipping. The handle has to be painted about a $100. I choose to let the dealer install it-$120. So $454 plus shipping. Is it worth it. In hind sight no. And nothing will short out, my button fell off 2 years ago and never had a problem. So the question is how important is it to you. Good luck
Old 05-15-2011, 06:19 PM
StUnT66's Avatar
2004 CL500
wow that isn't good at all. well thanks for the info I will figure out what to do next.
Old 05-25-2011, 06:48 AM
NAJLEPSI's Avatar
cl 500 2000
it's just simple switch, i will change it myself, because mechanic said new are good only for about 2 years...
Old 05-25-2011, 02:07 PM
StUnT66's Avatar
2004 CL500
So how is it a simple switch if we dont even know the part number for the button or proper door handle? do you have a part number you can share with the rest of us?
Any info you have would be greatly appreciated.
Old 05-25-2011, 07:22 PM
NAJLEPSI's Avatar
cl 500 2000
there is no part number for this, on my car (cl y.2000) you can pull rubber from the handle (it's covering the switch) and i can see switch under this rubber. but i dont know how to change it with new one. someone should take apart some old usless handle , to see if it can be done (i think it's possible). I lock my car now from the button on trunk because both (on door handle) are usless
Old 06-01-2011, 12:20 PM
NAJLEPSI's Avatar
cl 500 2000
I removed the rubber knob from door handle, just pull it out (cl500), dismantle micro switch and clean the contacts, but it still doesn't work for me
Old 03-10-2013, 12:09 PM
slonar21's Avatar
CL600 2003
If anyone is still looking for a button check my ebay listing
http://r.ebay.com/tFc1wZ
Cheap keyless door handle
Old 06-06-2013, 08:53 AM
charger383's Avatar
2005 cl65
Lightbulb fixed mine on cl65
Purchased used door handle for 99 bucks. Handle was beat up but had button intact. I removed the button carefully by inserting a small screwdriver and working/scraping the rubber frame around the button to remove it from the handle. Was careful not to tear the rubber frame around the button. The button itself is attached to this frame. I then scraped out the rubber frame from my cars door handle applied some super glue around the edge where rubber was removed and attached button and frame from donor handle. It worked but was a bit nerve wracking to not tear rubber frame. Felt better to do this vs. spending hundreds on new OEM replacement handle. Poor design that this button is not removeable and replaceable as a separate part but happy with the cheap fix overall.
Old 06-06-2013, 03:57 PM
Super Moderator
awiner's Avatar
2003 CL55 AMG
My drivers side button went out after several years. The button is only good for some many presses even if the rubber stays intact.
The button itself is encased in epoxy so removal even if one could be sourced is impossible.
Your right, would have made sense to make replacement parts, but that isn't the way it is
Old 01-30-2017, 04:43 PM
rfettig91214's Avatar
s430
buy part rh or lh from amazon..costs about $30 then u can use a clear sillicant to "epoxy" it in ...chhaper than going to MB..
Old 01-30-2017, 06:11 PM
tusabes's Avatar
Mercedes
have a link to the Amazon listing ?
i just used a piece of. Black electrical tape on my black door handle when the rubber button tore off . That piece of tape had stayed in place over two years so far !
Quick Reply: Door handle button is missing
