Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CL-Class (W215)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
CL-Class (W215) 2000-2006: CL 500, CL 600
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 12-01-2011, 11:01 AM   #1
STNTONU 510's Avatar
Drives: W215
w215 Car won't get out of Park and Brake lights are not working! Help please!!!
found out the problem! it was a blown fuse!
To remove this ad, register today or login if you already are registered!
__________________
Too Low For Fat HOES...
STNTONU 510 is offline   Reply With Quote
Old 12-01-2011, 02:26 PM   #2
Drives: cl500 2001
Most likely the little plastic shift linkage broke it's a common issue. Not sure why it would affect lights. Several posts here on the problem just fo a forum search using keyword shift.
nlieber is offline   Reply With Quote
Old 12-02-2011, 08:46 PM   #3
Drives: cl500 2001
Glad you got out of it cheap! Have to remember that as a possible issue. What fuse was it btw?
Old 01-29-2012, 04:29 AM   #4
Drives: 2001 cl 600
fuse
wich fuse was blown on the brake lights?
nightmare cl600 is offline   Reply With Quote
Old 03-08-2012, 10:24 PM   #5
acbaines's Avatar
Drives: 2003 CL600, AMG Sport Package, Eurocharged / 2009 Lexus LS460 AWD / 2009 SAAB 9-7X AERO 6.0 LS2
Hello All,
I hope this message reaches everyone who reads it doing well. My gear lever is stuck in park and my brake lights don't work on my CL600. I have tested every fuse in the car and all of them are good. I have removed the brake light switch, a new one is being shipped over night.
What fuse did you change that affected your brake lights? Where was the fuse located, the right side of the glove compartment, under the rear passenger seat, or if under the hood, the left side or the right side?
Thanks,
Anthony
acbaines is offline   Reply With Quote
Old 02-25-2013, 09:15 AM   #6
Drives: s500 / W220
Brake light fuse location
I've learned there is no safety fuse for brake lights but in fact a electronic circut braker. im having this issue right now. can anyone pin point the location of this breaker?
Dan Da'Barber is offline   Reply With Quote
Old 02-26-2013, 06:51 PM   #7
Drives: CL600 2003
Isn't this just the brake switch, I'm sure I read this before, it would be part of the pedal assembly as I remember
slonar21 is offline   Reply With Quote
Old 02-26-2013, 06:59 PM   #8
Drives: CL600 2003
Or this
http://www.benzworld.org/forums/w220...ols-heres.html
Tags
2000, 2001, brake, car, cl500, cl600, fat, hoes, lights, low, park, shift, w215, wont, work
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
