2005 CL55 AMG ABC/power Steering tandem pump help?
2005 benz cl55
I need to replace my ABC/Power Steering tandem pump on my CL55 AMG 2005. I found a company that is charging $949.95 for a NEW pump and said its factory OEM 1yr warrenty. I new feed back from you guys if this a good price or if anyone can get it at a better price. Also is OEM factory and whats the part number? Thank you
GL450
Parts.com shows dealer price $1,670.00, their price is $1,200.00. Part is listed as Steering, P/s pump & hoses, P/s pump, P/s pump, s430, cl500, s500, s600, w/active suspension - power, rack and pinion .
That looks like a good price if it's new OEM (which should mean Mercedes factory part).
GL450
Check the Mercedes EPC (Electronic Parts Catalog). The vendor should be able to tell you the part number, too, and you can look the part number up on parts.com for model reference.
Dear Mercedes lover
Most of ABC PUMP major problem is leading fluid cause to fails to maintain replaced hydrolic fueler ,I suggested if you have any problem with ABC do not buyer remanurfature it not work on your car will cost you more for labor to remove
