Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CL-Class (W215)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
CL-Class (W215) 2000-2006: CL 500, CL 600
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 02-05-2012, 01:12 AM   #1
Drives: cl500
CL500 Power Trunk Problem Coversion/Solution
Greetings! First, Thank you for all the help through the years. My 1st post:
I have 2002 CL500 w/ power trunk lift and close. While under warranty have had trunk 'normalized' (adjusted), for not open/closing correctly, several times throughout the years. Every time i'd check into a hotel, the valets would not wait for the power close and slam it...throwing it out of adjustment. Now out of warranty, dealer says "shock and pump are bad...$1500+.
Rather than pay (~$900+ pump, ~$150+ ea shock + labor), i converted it back to springs for under $100.
Now works beautifully with remote unlock and no error mssgs.
1st: Purchased used springs from ebay for $85. I used EuroChopShop (http://stores.ebay.com/Euro-Chop-Sho...id=p4340.l2563).
Below: There are 3 wires the come from the pump which is directly under the battery. Disconnect the only one that has a plastic coupling as shown-
Below: There is a plastic cover on both sides. Wiggle out, pulling forward (takes some force). You will leave these out when the new springs are installed. I think they are cosmetic covers for the pneumatic shocks as the new springs will need this room to move up and down.
Below: There are 5 bolts. I removed 4, leaving the top adjustment bolt loose.
Below: Once the 4 bottom bolts are off you can move yourself to one side and lift the trunk off of the remaining bolt and rest it gently on the rubber trunk seal.
Below: When you remove the passenger bracket and shock, there is a gear that must be wiggled out. The drivers side does not have this and is simply removed via the bolts.
Reverse the procedure to install the springs. You may have to adjust the bolts to have a perfect closure. I had to adjust very slightly to have my seam lines uniform.
Now my trunk springs open about 50% when i use the switch from inside the drivers door like a regular trunk. Once i get out i simply push it the remaining way open, once again, like a normal trunk.
To close, i gently push down to latch. The auto pull down grabs it and closes it securely.
For me this works and saves me from valets constantly pushing the old auto close down and screwing it up...not to mention $1500.
Thanks and i hope my 1st post is acceptable!!
Good driving!
To remove this ad, register today or login if you already are registered!
CL500 Power Trunk Problem Coversion/Solution-cl500-trunk-pump.jpg  CL500 Power Trunk Problem Coversion/Solution-cl500-disconnect.jpg  CL500 Power Trunk Problem Coversion/Solution-cl500-trunk-resting.jpg  CL500 Power Trunk Problem Coversion/Solution-cl500-plastic.jpg  CL500 Power Trunk Problem Coversion/Solution-cl500-trunk-bolts.jpg
CL500 Power Trunk Problem Coversion/Solution-cl500-bracketgear.jpg
Vegasheat is offline   Reply With Quote
Old 02-06-2012, 06:37 PM   #2
Drives: cl600
what car was that spring out of?
thanks, very interesting!
biker349 is offline   Reply With Quote
Old 02-06-2012, 06:49 PM   #3
1995E320Cab's Avatar
Drives: 2003 CL600 2005 745Li
Great post thanks for sharing !!
__________________
__________________
2003 CL600 V12TT - SPEEDRIVED ECU / TCU, AMG Package, AMG Brake Package, K&N's, Muffler Delete, Star and Links Lowered, Car Diet - Down 70lbs and counting....
1994 E500 - Sold
1995 E320 Cab - Sold
1988 BMW M6 - Sold
1994 E320 Cab - Sold
[/size]
1995E320Cab is offline   Reply With Quote
Old 02-07-2012, 02:23 AM   #4
Drives: cl500
Don't know what year or even model it came from. When I purchased them from Ebay the description said:
TRUNK HINGES SPRINGS Mercedes W215 CL500 CL55 CL600 CL65 2000 01 02 03 04 05 0
Fits: 00-06 CL500, CL55, CL600, CL65, Part Number 2157500387 . 2157500487.
Here's the actual link*:
http://www.ebay.com/itm/130630686738...84.m1497.l2649
*This is from Feb 2012. Ebay will delete this link in a couple months if it didn't work for you.
Thxs for the question!
Old 02-08-2012, 07:35 AM   #5
saintz's Avatar
Drives: 2003 CL600
Thanks for posting this up. I have repaired a leaking ram/shock with epoxy and refilled the pump (twice). This part is really a terrible design. This seems like a good solution for anyone that wants to permanently fix it.
__________________
2003 CL600 - Eurocharged
2009 C300 (wife)
2001 E55 AMG - RENNtech Stage 1, Lorinser (sold)
1999 CLK 320 (sold)
2003 WRX, Stage 4 (sold)
saintz is offline   Reply With Quote
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
2002, 500, 500cl, cc, cl, cl500, cl55, conversion, e55, hydraulics, lift, manually, mb, mbz, motor, open, power, trunk
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
