Aluminium/rubber studded OEM pedal covers available for 215?
Hi,
I tried checking it with my local MB dealer but they are clueless.
This is the pic of someone's W220. I take it the covers + gas pedal assembly would be the same for 215? Anyone has part numbers?
1 Post
05,cl65;33ford3wc.
The pedals on my 05,cl65 look like what you want, I,m surprised the dealer didn't advise You, probably pricey though,but a correct fit. You may check after market, but be prepared to sweat the correctness thing. Last thought, check out parting amgs.
'03 CL500,& '18 GLS63. Gone: '83 500SEC,'99 500SL,'07GL450
accel: 164 300 00 82
brake : 170 290 01 82
emerg: 164 430 00 84
Hi and thanks for your replies.
@ dtohio. I will check the CL65 covers. I'm after original parts only.
@ reddog. I fitted said pedal covers to my wife's 08 ML420 and the gas pedal in ML is different to that of a 215 CL. Have a look.
My 04 CL55 has them. The 03 didn't. So you want the 04 and newer parts for the AMG models.
And every part number you ever want can be found here: https://epc.startekinfo.com/epc/home.jsp
UPDATE
W215 CL65 has studded pedals as standard. The part numbers are:
A220 300 03 04 Accelerator pedal assembly
A230 430 00 84 Brake pedal cover
A320 290 00 82 Foot brake pedal cover
In my Mercedes dealer's EPC software, they are only listed for CL65 not CL600, hence they were unable to find them. They are not listed as an AMG accessory either.
Googling the accel pedal part number shows this:
The question of the day, do CL65 and CL600 accel pedals share the same internals? Dealer was unable to answer this (obviously) as they are listed as different p/n. Anybody here retrofitted the pedal off CL65 in to CL600 TT? Don't want to buy a $250 part to find out!
Thanks.
Thanks.
This is for the 11-14 S and CL
Notice the nubs. The earlier styles were like dots, the later styles are ovals in two rows and yes they will work the same, I changed mine on my 06 CL an exact match.
I purchased mine from this seller last year
http://www.ebay.com/itm/OEM-MERCEDES-AMG-SPORT-PEDALS-R129-W124-W140-SL-500-600-CLK-W210-W211-MANY-MORE-/121355467876?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c41597c64&vxp=mtr
