Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > CL-Class (W215)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
CL-Class (W215) 2000-2006: CL 500, CL 600
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-13-2012, 07:05 AM   #1
Drives: CL 600
Cool Transmission trouble
Hi Everyone
It would seem that my 2000 CL600 has come to the end of its life. (265 000 Kms).
After driving the car for 20 mins, I attepmted to park it, placed it in reverse, and only had neutral. I then turned the car off, and back on again and had reverse.
3 Hours later I started the car, and drove off. I noticed a whining noise and suddenlt the car lost all drive while on the freeway. I pulled over, restarted the car, and the gears were back, along with the whining noise.
I then parked the car, and took it to the shop the following day. On the way to the shop, the car kept losing drive. This happened 4 times in 10Km.
The car is full with transmission fluid, but is making the sound it would make when low.
The mechanic has just told me that there is a problem inside the transmission, as they have done all of the cleaning of harnesses and so on.
What could the problem be here?
Thanks in advance
To remove this ad, register today or login if you already are registered!
Jay Kay is offline   Reply With Quote
Old 04-13-2012, 07:15 AM   #2
saintz's Avatar
Drives: 2003 CL600
I think you have a transmission rebuild or swap in your future. Given how simple and common the 5 speed is, that might not be too bad. Best to get a quote from your mechanic. Possibly just a valve body swap is required.
__________________
2003 CL600 - Eurocharged
2009 C300 (wife)
2001 E55 AMG - RENNtech Stage 1, Lorinser (sold)
1999 CLK 320 (sold)
2003 WRX, Stage 4 (sold)
saintz is online now   Reply With Quote
Old 04-13-2012, 07:28 AM   #3
Drives: CL 600
Thanks for the speedy response. I will have a quote by next week.
Old 04-14-2012, 10:16 AM   #4
Drives: cl600
how old is your fluid? if it's over 40,000 miles the fluid may be contributing to the problem.
biker349 is online now   Reply With Quote
Old 04-16-2012, 03:26 AM   #5
Drives: CL 600
The fluid & filter were changed 3 weeks ago
Old 04-16-2012, 09:31 PM   #6
Super Moderator
awiner's Avatar
Drives: 2003 CL55 AMG
How many miles did you have on the old fluid before the change that is now causing some issues ?
__________________
Adam
2003 CL55 V8 Kompressor
Parktronic, v60 Phone, Keyless Go, Trunk Closer, Painted Front Side Lenses
MP Designs Sport Steering Wheel, 19" HRE 847R's, Brabus Lowering Module
Ice>Link Plus iPod Photo 40GB Color Integration into Factory COMAND
2005 MV Agusta F4-1000
2005 Kawasaki ZX-6R (636)
awiner is offline   Reply With Quote
Old 04-17-2012, 04:41 AM   #7
Drives: CL 600
Not more than 20 000 kms.
Old 04-17-2012, 11:15 AM   #8
Drives: CL 600
Today I had to drive the car from the mechanic, to the body shop. It was only 2kms, but the car felt normal. It was stop and go, but the shifts between 1st and 2nd were smooth as normal. Never got a chance to run through the rest of the gears. The car was cold, so no idea if it would run any worse when warm...
Old 04-20-2012, 04:30 AM   #9
Drives: CL 600
Codes...
So I have had the car scanned, and the following problems come up:
110 - The speed comparison of Y3/6n2 to Y3/6n3 is sporadically implausable. (Resistance too low)
116 - Component Y3/6s1 (Starter lockout contact) or component Y3/6b1 (Transmission oil temperature sensor) is sporadically faulty or both. (Resistance too low)
146 - The transmission has sporadically an impermissable transmission ratio. (Resistance too high)
147 - The gear is sporadically implausable or the transmission slips sporadically. (Resistance too high)
151 - the gear comparison is sporadically negative or the target gear has sporadically not been achived. (Resistance too high)
Any asistance with this matter is most welcome.
Old 04-25-2012, 05:36 AM   #10
Drives: CL 600
....no response....
Looks like everyone who has read this is stumped!
My thoughts are to replace the condutor plate, remove, clean and inspect the valve body...
I will first drain all the fluid out of the transmission, including the torque converter. I will alow it to drain over 24 hours, and only then begin repairs...
Any advice or thoughts will be most welcome.... I feel very much alone here....
Tags
116, 151, achieved, cl600, component, correct, fluid, gear, negative, oil, sensor, sporadical, target, temp, trans, transmisson, y36b1
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
