Sign in using an external account
| CL-Class (W215) 2000-2006: CL 500, CL 600 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2001 CL500
CL500 Rear Power Window does not work !
#2 |
Drives: 97 Lexus LS400, 04 Mustang, 08 Corvette Z51, 92 Honda Civic Si, 02 CL500
Most likely, it's the window regulator. Press the rear window switch & listen. If you can hear the winding sound then the switch & motor are ok. Check on Ebay for a used one, it usually run for under $100. Good luck.
| Tags |
| 2001, 2006, 500, benz, cl, cl500, fuse, location, mercedes, power, problem, rear, relay, window, work, working |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
