Replacing my valve body...
2004 mercedes cl 500
Hi, guys i have a quick question if im replacing my active body control will i need to reprogram it ? or if i use used one with same serial numbers i do not need it ?
2004 CL500
If you are talking about the ABC valve bodies under the car then no you can either just swap them out for good clean used ones, or clean your existing one. There is no programing of the suspension needed.
