CL-Class (W215) 2000-2006: CL 500, CL 600
DIY Front Brake Removal Question
Old 05-26-2014, 09:04 PM
esoteric83's Avatar
CL500
How many bolts to remove to remove the calipers? i removed 2 but still not coming off. Please help. Did my back brakes fine
Old 05-27-2014, 03:24 AM
Welwynnick's Avatar
2006 S600
Two
Did you push the pads back with a lever?
Does the caliper moev at all, or is it still clamped?
Nick
Old 05-28-2014, 12:29 PM
esoteric83's Avatar
CL500
I don't push the caliper backs it have lever but the rotors move freely. I remove both upper and lower bolts but it's like there is a 3rd bolt somewhere and it frustrating the hell out of me
Old 05-30-2014, 04:29 AM
Welwynnick's Avatar
2006 S600
I've never come across a brake caliper that wasn't fitted with two large bolts.
What you could do is put the bolts back in very loosely and hit the caliper with a big lump of wood.
Old 05-31-2014, 01:42 PM
esoteric83's Avatar
CL500
I'll try it again. Very frustrating. I've changed brakes many times in the past. I'll just hit it with the wood and see if it can free itself loose
Old 05-31-2014, 02:40 PM
Welwynnick's Avatar
2006 S600
Are you changing the pads or the rotors?
Nick
Old 06-01-2014, 11:26 AM
esoteric83's Avatar
CL500
Just changing the pads. I did my back brake pads yesterday with no problem
Old 06-01-2014, 02:18 PM
Welwynnick's Avatar
2006 S600
Do you have fixed or sliding calipers? If they're 4 piston fixed calipers (probable) then you should be able to remove the pads without removing the caliper.
Old 06-02-2014, 04:04 PM
duhdenmark's Avatar
CL600
If there is a lip on your discs, then the pads are difficult to remove.
David
Old 06-08-2014, 09:16 PM
esoteric83's Avatar
CL500
Ah. I did the fronts today. I didn't realize all you had to do is remove the pins and not the 2 bolts on the inside of the caliper. I was making it more difficult than it actually was. Probably one of my easiest brake pad changes in all of my cars. Thanks for the input everyone.
Quick Reply: DIY Front Brake Removal Question
