Cant access ABC, ESP/BAS, nor "electronic shift lever" modules via SDS anymore
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Hi, i cant access the 3 modules anymore via Star Diagnosis System.
Star cant connect to ABC Module, neither to ESP/BAS module nor to the "Electronic shift lever selector" (however its called in english) modules anymore.
According to FSM they are all Part of the Chassis Can-Bus, end in the central gateway and from the central gateway you can diagnose them over the diagnostics Port K-Line. Is this correct?
The Car is working perfectly. ABC is working, ESP is working and of course i can select gears. Just cant diagnose it anymore which is bad.
Anyone know where to look at? I almost lost my mind already on this as the electronics on these cars are so complex. Well any help appreciated. Thanks.
