AC not blowing
AC not blowing
The motor is good (turns if I apply 12v), the resistor is good (I replaced with new).. Does anyone know the voltages on the input to the resistor i.e. for the red/yellow, green/gray, (and assuming brown is ground) leads. Also, the voltage from resistor outputs, red and brown that go to motor?
What is next up the chain? I know there is a sensor above the gas pedal but don't know what it is or where else I should look.
I'm not getting any error codes (holding REST and FILTER buttons), and since I am getting "some" voltage at the inputs to the resistor so don't suspect fuse.
signed.. Hot in Texas (and not in a good way ')
would appreciate the answer. what other site? do you have a link?
Not sure what the 'link' rules are here but,
http://www.benzworld.org/forums/w215...t-blowing.html
PM me here if I can help, or post in that thread for details.. good luck..
thank you!!!
