CL-Class (W215) 2000-2006: CL 500, CL 600
lights issue and navi
Old 03-06-2015, 11:02 PM
alqatou's Avatar
CL500
Hello
I am new here and this my first post
I purchased a Mercedes cl500 2004 a very nice car with 104k on it clean car but has some issue
when I first purchased the car it was seating on the floor one of the ABC hose was blowing and the pump was weak so I replaced all the above and car rise normal now I still have a ABC error code
Rear right shock valve but the car never sag on any side and the tech told me it is OK to keep it like this until I replace the shock
Now the real problem
Whenever I start the car and turn the lights on
I keep getting lights error msg but the lights work just fine except the third brake light and one more on the rear right the additional one?
Bulb work fine and the third brake light if you powered it work
In addition, the scanners give me these codes
B1629 left front parking lamp faulty
B1633 side marker lamp left E6/3 component error
B1341 siren and battery communication error
B1629 component right standing and parking lamp in module E2 right front headlamp unit is faulty
B1637 illumination front dashboard defect
B1616 component E4E8 right tail lamp additional in module E4 right tail lamp is faulty
B1621 brake light center high E21 component error
Please if anyone can help to solve this errors
In addition, navi not working keep telling me navi not available and my teleaid /SOS defective it msg I turn it off using scanner but when I start the car it telling me the teleaid/sos defective?
i really appreciate any help
thank you
Ryan
Old 03-07-2015, 12:30 PM
biker349's Avatar
cl600
maybe try disconnecting the battery for a few hours and see if it resets. be sure to reset your windows and esp system afterward. do you have a star diagnostic tool? did you try resetting the codes with star? they should resett if you delete the memory on the star. if they come back after that you'll have to check each problem.
Old 03-07-2015, 01:23 PM
alqatou's Avatar
CL500
yes i did disconnect the battery and nothing happen
i don't have a star but when i replaced the p/s pump they rest it and told me i have couple of module error ?
and they turn off the telaid /sos but when i start the car still telling me its defective
thanks
Old 12-29-2015, 02:10 PM
Dmtypr's Avatar
Clk w209 AMG
sam?
Old 12-29-2015, 05:29 PM
tusabes's Avatar
Mercedes
I'm betting his trunk electronics got wet which would affect the lights and navi
Very common problem
Old 12-30-2015, 01:51 AM
Dmtypr's Avatar
Clk w209 AMG
Very common problem
Could you elaborate more specifically ? This caught my attention preparing for plan B if after replacing my rear sam issues continue...
Old 12-30-2015, 05:47 AM
tusabes's Avatar
Mercedes
My trunk got wet causing $6500 damage . Insurance took care of it
Very common problem
On the 215 chassis
lights issue and navi-744f6a98-7e65-4d59-8091-fcfa2f75e4da-569-0000005fda49fa30_zpsd4fb49ff.jpg
lights issue and navi-7d705b4e-3d9d-4bbd-a346-f25faa7c56cd-5282-0000049b6a1c4ec9_zpsdfe1ed66.jpg
Old 12-30-2015, 06:47 AM
Dmtypr's Avatar
Clk w209 AMG
How does this affect the brake lights? Seems interesting Im having [No sound] on my radio before having troubles with parking brake light.
Anything in particular the Dealer changed?
Old 12-30-2015, 11:41 AM
tusabes's Avatar
Mercedes
It's all related , my radio went out too, water gets in there and damages everyting
Old 12-30-2015, 11:56 AM
Dmtypr's Avatar
Clk w209 AMG
But "where?" exactly? Did they replace the sam also? If so could make more sense. But little water in where the DVD sits does not seem to me would cause so much drama. Which in turn is what I found....Lots of water in the battery area and little water in dvd area. I think my rear sam is out due to water damage cant wait to replace it to see what happens
Old 12-30-2015, 11:59 AM
tusabes's Avatar
Mercedes
Both sides , by battery and cd changer . My Sam did not get damaged because i caught it quickly before it entered passenger compartment . If you drive with the water it will slosh around under the passenger floor causing $10-20k damage
Note this will reoccur over and over again if you drive in the rain or leave your car outside
Old 12-30-2015, 12:17 PM
Dmtypr's Avatar
Clk w209 AMG
But are you talking about rust damage done? Or components? I would like to know the components the dealer changed..
10k to 20k seems way to high
Old 12-30-2015, 12:19 PM
tusabes's Avatar
Mercedes
No not rust damage , just electrical components
the labor alone is several thousands of dollars to remove the interior and trunk and each component is near $1000. You have the power trunk , the pse, cd changer , amp, nav, sams , wiring harnesses, seat modules etc.
Of course that is Mercedes dealership prices and new parts
If you do the work yourself and find used parts it can be done for much less
Old 12-31-2015, 10:46 PM
fireman685's Avatar
2005 CL55
Where does the water leak into the trunk from? Mine is a daily driver and at the moment don't have covered parking. If like to know so I can be proactive.
Old 12-31-2015, 11:48 PM
tusabes's Avatar
Mercedes
Any variety of places , sunroof drains , reed valve under the windshield , trunk lid , taillights . They all are ways for water to enter the front or rear
If you have the power trunk make sure it always closes fully
http://www.edmunds.com/mercedes-benz...trunk-lid.html
Quick Reply: lights issue and navi
