CL-Class (W215) 2000-2006: CL 500, CL 600
Transmission in cold weather
Old 01-23-2016, 12:50 PM
Kcnyc's Avatar
Cl500
Good day, team. Need advise.
As soon as it got colder in NYC I've noticed that my car's transmission is a bit rough in first gear and doesn't switch to second smoothly. Once the car is warm and I drive a mile or so it's all back to normal. Also sometimes when it downshifts (I'm guessing from 2nd to 1st gear) i feel a little kick.
Is this normal behavior for cold weather or I should be worried?
Also, can I refill the transmission fluid?
Any suggestions appreciated.
THank you in advance.
Old 01-23-2016, 04:23 PM
tusabes's Avatar
Mercedes
Depends what car you have you don't list the year , Mercedes changed from
A 5 speed transmission with a capped dipstick tube To a seven speed with no dipstick tube
For the five speed you need to buy the Mercedes dipstick tool
You should just have the fluid and filter changed (pan dropped) do not have it "flushed "
Old 01-23-2016, 04:30 PM
tusabes's Avatar
Mercedes
Also if you have the 5 speed (2000-2003 cars and all 600 and Amg 55) when doing the fluid change , change the transmission electrical plug which often leaks internally causing fluid to damage the electronics
How to change transmission electrical plug
(Fluid leaks into wiring)
Old 01-23-2016, 04:32 PM
Kcnyc's Avatar
Cl500
it's a 06 cl500.
I remember when I had a 97 bmw 528i it said in a manual that transmission fluid was lifetime, however when mechanic changed the fluid it was shifting like a brand new car (had issues before that). Do my symptoms sound like the car would benefit from tr.fluid change?
Old 01-27-2016, 08:27 AM
fireman685's Avatar
2005 CL55
My 05 CL55 has the same issue although the trans won't smooth out until its completely warmed up. To me it almost feels like the torque converter clutch is engaging to soon. The shifts from 1-2-3 are usually pretty hard and if you hearing the car from the outside you'd swear I was just learning how to drive a manual. It'll do it in sport or convenience mode. I haven't tried shifting with the buttons on the wheel yet. It's got 115k miles on it now. The fluid, filter and electronic plug were replaced about 20k miles ago. Oh, and seems to downshift weird as well.
Old 01-27-2016, 08:34 AM
Kcnyc's Avatar
Cl500
Thank you for a reply
Sounds exactly like my challenge. Please let me know if you find a solution soon. I will do the same.
Old 01-27-2016, 03:55 PM
fireman685's Avatar
2005 CL55
Will do.
Quick Reply: Transmission in cold weather
