CL-Class (W215) 2000-2006: CL 500, CL 600
Headlights help
Old 02-07-2016, 03:29 PM
elidari's Avatar
S500
Headlights help
Hi I really need help how to remove the headlights From my 2006 CL W215 any help appreciate it thanks Eli
Old 02-07-2016, 07:01 PM
tusabes's Avatar
Mercedes
Just the bulbs or the entire headlight assembly ?
Old 02-08-2016, 01:42 PM
elidari's Avatar
S500
Headlights
The Entire Headlights
Old 02-08-2016, 11:08 PM
graytalon2000's Avatar
05 CL600
The front bumper must be removed to remove the headlights.
Old 02-09-2016, 03:39 PM
elidari's Avatar
S500
I was hoping not to remove the bumper what happen is I lost a lightbulb inside the headlights and I cannot get it out
Thanks Eli
Old 02-09-2016, 03:57 PM
tusabes's Avatar
Mercedes
Use a flexible grabbing tool
http://m.harborfreight.com/24-inch-2...not%20provided
Old 02-09-2016, 04:17 PM
elidari's Avatar
S500
Thanks for the tip I was hoping for something a little better since I am on wheelchair it's will be very difficult
thanks Eli
Old 02-09-2016, 10:37 PM
tusabes's Avatar
Mercedes
It will be much more difficult to remove the entire headlight assembly , esp if you are working from your wheelchair . You might need to hire a mobile mechanic . I've had good luck with the Yourmechanic.com service , they can come out and help you . I've used them in SF
Old 02-10-2016, 06:41 PM
elidari's Avatar
S500
Thank you very much second question do you know by any chance the different between W215 and W216 thanks
Old 02-10-2016, 06:48 PM
tusabes's Avatar
Mercedes
W215 is the 2000-2006 year
The car was redesigned for 2007 and is a completely different model called the w216 , cl550
Old 02-11-2016, 01:43 PM
elidari's Avatar
S500
Thank you so much for your expertise
Quick Reply: Headlights help
