Cl500 No start , nosie on ingition
Hello I have a problem with my CL500 2000 Auto Turn-ons starter lights and immediately goes out . NOTE rotations goes to the top and falls the lack of any sort of error codes , fuel reaches the injection because he was checking . as 'll keep the gas pedal but it fires hard and choking felt as if he could not burn fuel and then goes out , she takes a breath. For the ignition of the mask on the back of the engine hear a strange sound . below the video What can be wrong?
It behaves as if it flooded
https://www.youtube.com/watch?v=VSG_LEqciFs&feature=share
I was doing in my car suspension . before the engine worked and everything was okey engine worked . After changing the shock absorber , swing arm , crossover does not work . if not getting fuel or flooded . Move these wires marked in the picture . what could happen if they are fuels ? after changing the suspension of the engine is not running. here you can look for the cause ? please help
Go back and look over every cable and hose you moved to do the suspension work
Something is either not plugged in fully or got damaged . If there were any electrical connections , unplug them clean them and reconnect tight
